Ford Range This section is for other models in the Ford range.
Garage cost to remove turbo?
Old May 24, 2011 | 09:21 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Garage cost to remove turbo?
How much roughly would a garage charge to remove a oil and water cooled GT2554R turbo from a 1.8 focus? It's standard exhaust manifold with 3 studs securing to turbo itself like below-
Can be seen here too-
Just because turbo needs work done as it has oil leaking and blue smoke. Boosts fine and no play at compressor wheel so "should" be just seals and actuator sorting, plus storage while turbo is away and then refitting.
Old May 26, 2011 | 04:12 PM
Camel Fiddler
Had a quote of 2 hours at £42/hour for removal of turbo and then 2 for replacement with free storage so £168 Inc vat. That about right? I was thinking £300 tbh so seems ok to me.
Old May 26, 2011 | 04:57 PM
LukeDaisley's Avatar
LukeDaisley
Are you shitting me? £300 for that. I would drive up from Essex and do it for that.
even at a garage I would only want to pay tops £150.
BTW, how does the bottom water pipe clear your down pipe?
what water pump are you running?
Thanks Luke
Matt Baxter
Sep 16, 2015 08:30 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
