Running in a Newmans cam - how do you do yours?
Hi,
Rang newmans and was informed not to run the cam in the kent/piper way, instead "take it easy for the first 100 miles".
Where as burtonpower informed me to run at 2500k for 20mins.
Which is best for this camshaft?
Many thanks
Many thanks
2500k for 20 minutes.
Spoke to my tuner the other day about this as i'm fitting a cam in a few weeks. He said that camshafts don't come completely smooth from the manufacturer so you need to smooth off the lobes by running them at a constant rpm for around 20 minutes. (or two lots of 10 minutes depending on your cvh's temps! lol)
Also make sure your oil levels are topped up.
I think I have misunderstood him. I see what you mean by the cam is soft. Just read this on pumaracing.com "The key thing is not to let the engine idle. Letting the engine idle can wear the peak of the cam lobes away before they have had chance to bed in". Hence the lube I suppose.
So when fitting a new cam you need to fit new lifters as well?
That what I meant with the cam lube as I read that anything under 1500rpm (ish) will not have sufficient oil supply and cause the components to score/wear? so for the initial start up.
I think I need to start paying more attention to people when they are telling me these things
rog
Sep 4, 2015 07:24 AM
