Cold start problem
Old May 23, 2011 | 09:42 AM
Sjieter's Avatar
Sjieter
Default Cold start problem
On a coldstart with the coldstart injector connected my car start very fast but dies instantly. After that i need to start is for like 3 seconds. When i disconnect the cold start injector i need to start for like 4-5 seconds and keeps running it doesn't die.
I've put on a new cold start switch. I also think the car is running a little rich, sooth on the exhaust and it smells. Would a setup solve all the problems?
Thanks
Sjieter's Avatar
Sjieter
Oh yeah it's a rs turbo s2 still on mfi
Old May 25, 2011 | 04:54 PM
crossy2004's Avatar
crossy2004
set up will solve problem mate as for cold start u dont really need to have it plugged in
Old May 25, 2011 | 05:34 PM
Sjieter's Avatar
Sjieter
The co pot on top of the meterhead is that for idle only or for general?
Nobody at my work ( Ford garage ) knows how the system works (mfi ).
I always thought that the screw behind the black box on the side of the meterhead was for mixture in general.
Problem is I don't know any garage near me that knows the Mfi system, maybe i should ask around for a tuner in my country that knows it.. hope their won't be cowboys that say they know the system and fuck up my car
Thanks
Old May 26, 2011 | 08:04 PM
crossy2004's Avatar
crossy2004
no there is a allen key screw on top of your meter head back of k+n or under airbox depends on what filter u use to adjust fuel and to adjust air fuel mix is under the throttle body. the black box is your fuel measurer unit
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
