Stud conversion.
Old May 19, 2011 | 01:00 AM
Chopshop85's Avatar
Chopshop85
Default Stud conversion.
Does anyone have any pictures of their's? Had a search but didnt manage to find any.
Is it easy to do? safe?
cheeRS
Old May 19, 2011 | 12:53 PM
RSandy's Avatar
RSandy
cylinder head stud, or wheel hub studs?
Old May 19, 2011 | 01:57 PM
Rob_DOHC's Avatar
Rob_DOHC
Onlu pic i have unfortunately
Might have some more at home....
Easy enough, drill out the hubs, press in the studs, easier to get a machine shop to do it, but not impossible to do at home.
Rob,
Old May 20, 2011 | 10:11 AM
Rob_DOHC's Avatar
Rob_DOHC
? were you talking about wheel studs
Old May 20, 2011 | 12:18 PM
Chopshop85's Avatar
Chopshop85
Yes mate!, I just thought that myself reading back what I put.
car in the pick looks minty mint!
Old May 20, 2011 | 02:09 PM
Rob_DOHC's Avatar
Rob_DOHC
Cheers mate, its getting there.
I would definitely recommend the wheel studs btw, its so easy to strip the threads out of the hub with normal bolts.
I bought the studs from rallydesign.com
Rob,
Old May 20, 2011 | 03:06 PM
RSandy's Avatar
RSandy
just make sure for the love of god u fully drill out the old threads. i sent my hubs off to have the work done, and somehow 1 of the holes was missed, and a stud was pressed in with thread still in place. result, 1 cracked hub
for such a cheap and simple job, it dont half make a world of difference though. no more fighting to line up bolts thru constantly spinning brake discs, and fighting to hold a wheel in place whilst u try and find all the bolts lol
Old May 20, 2011 | 09:36 PM
slimwynn's Avatar
slimwynn
why is having studs better than having the normal set up?
i can see what RSandy is saying it would make it a lot easyer lol just wandered if there was another reason.
Old Feb 2, 2012 | 04:27 PM
rapidonion's Avatar
rapidonion
im going to drill my hubs tomorrow on the pillar drill in work, what size bit did you use? 12mm?
cheers mike
Old Feb 2, 2012 | 05:20 PM
phil_rs's Avatar
phil_rs
yam yammer
cheers mike
I ordered my studs from Burton Power which should be 12.5 but found them closer to 12.6mm. I had a decent 12.5mm drill but wasn't quite big enough so I ordered a good quality 12.6mm drill bit off ebay. I used a pillar drill and then a vice to press them in
This is the drill I bought
http://www.ebay.co.uk/itm/DORMER-A10...#ht_500wt_1127
Old Feb 2, 2012 | 05:27 PM
rapidonion's Avatar
rapidonion
cheers mate
Old Feb 2, 2012 | 05:30 PM
phil_rs's Avatar
phil_rs
yam yammer
Old Feb 2, 2012 | 07:00 PM
Rogeyboy's Avatar
Rogeyboy
Rather than pressing the studs in, you can just do a nut up on them to pull them into place i think...
Be careful when drilling them out, you can't go too wrong as the drill will follow the thread hole, but make sure it doesnt wander off and go thru on the wonk.
Old Feb 2, 2012 | 07:33 PM
Rob_DOHC's Avatar
Rob_DOHC
As Roger says, I also put my studs in the freezer and my hubs in the oven, made installing the studs very easy.
Rob,
Old Feb 3, 2012 | 07:06 AM
Rogeyboy's Avatar
Rogeyboy
Look at you making use of the kitchen appliances lol...
I bet the Mrs loved that!?
Nice idea tho!
Old Feb 3, 2012 | 10:31 AM
Rob_DOHC's Avatar
Rob_DOHC
Nice idea tho!
haha, I find the trick is to wait until she's gone out!
Rob,
Old Feb 3, 2012 | 11:16 AM
phil_rs's Avatar
phil_rs
yam yammer
Have you tried the old cylinder head in the dishwasher trick lads? Works a treat!
Old Feb 3, 2012 | 11:49 AM
Rogeyboy's Avatar
Rogeyboy
I am aware of it, but havn't tried it. Come the summer i'll want afew bits cleaned and degreased so i'll give it a go - what program's best lol? I don't imagine the "eco-wash" program is much use for engine parts it barely cleans off last nights ruby murray!
Old Feb 3, 2012 | 12:09 PM
Rob_DOHC's Avatar
Rob_DOHC
The dishwasher isn't any good for ali heads i find, great for blocks tho, but seriously WAIT UNTIL THE MISSUS IS OUT!
The hotter the cycle the better, just get rid of any degreaser etc first as it stinks enough to get you in trouble when she's back!
Rob,
jessie_rs
62
Aug 6, 2019 09:27 PM
Cosnada
Jan 7, 2016 05:30 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
