kangarooing
Old May 15, 2011 | 08:58 PM
sykes2009's Avatar
sykes2009
Default kangarooing
my mk2 has decided to through a fit
its not as bad when cold but once warm it back fires a lot
i have checked spark plugs 134 but not 2 as i could not get it undone and did
not want to break it but the others didnt seem to be that bad i have only just realised it hasnt had a service for a while anybody got any thoughts
Old May 18, 2011 | 05:08 PM
sykes2009's Avatar
sykes2009
just found out the problem to this, its more common on the 1.6 (which is what i have)
there is water in the spark plug well's believed to be coming in from the washer jets as these sit directly above the spark plugs apparently ford no about this but will not recall them
instead new washer jets with a rubber seal have to be bought wich is somthing im going to do
but the main thing im absolutly shiting myself about is 1 spark plug is stuck because of the rust if that breaks i am fooked the car is at the garage now i will find out the result tomorrow
Old May 18, 2011 | 09:11 PM
sykes2009's Avatar
sykes2009
also found a stainless cover to go over the spark plugs here
http://www.teamtorquesteer.co.uk/foc...ker-cover.html
would this be ok i mean would it create any unwanted heat to the plugs and leads
Old May 18, 2011 | 09:19 PM
RichieST's Avatar
RichieST
Similar thing happened on my mrs's old fiesta, rain water leaking through the washer jets into the spark plug wells, new jets with a small amount of sealant sorted it. You sure it's not the coil pack that's gone tits?
Old May 19, 2011 | 06:52 AM
Bailes1992's Avatar
Bailes1992
Owchhh Ł50?
Get one off an early focus/fiesta
Old May 19, 2011 | 05:15 PM
sykes2009's Avatar
sykes2009
well just got it back it turns out the rubber washer for the washer jet had been put on the wrong way around (not by me before i bought the car) they have been turn the right way also like you said rich with a bit of sealent,
the spark plug is still stuck so im going to squirt a bit of penetration fluid in the spark plug well once a week for a month then see if it will loosen, if not then try for 1 more month then after that a lot of force will be used with a long ratchet
if it loosens then but if it snaps then its a head of job at Ł700
Old May 20, 2011 | 07:39 AM
Bailes1992's Avatar
Bailes1992
Don't need a new head. Just get the head off and drill it out
Old May 20, 2011 | 03:57 PM
sykes2009's Avatar
sykes2009
yeah thats what i ment
Old Oct 9, 2012 | 06:07 PM
halshaw1's Avatar
halshaw1
Hi guys my 1.6 1999 focus is kangerooing when i take foot off accelerator.appreciate any feed back thanks
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
jedi0_3
Jul 17, 2007 04:58 PM
turboash
Fiesta RS1800/RS Turbo
Aug 22, 2006 06:44 PM
deankenny
Mar 24, 2006 07:43 PM
MOONDUST FRST
Dec 3, 2005 03:37 PM
