escort kangaroo
Old Mar 22, 2006 | 10:30 PM
deankenny's Avatar
deankenny
Default escort kangaroo
have a 1.6 zetec escort, L reg.
most of the time it runs great but occassionally, usually about 10 mins into a journey, it starts to "splutter". When i accelerate it drives then stops firing then fires for a few seconds then stops for a few seconds etc. if i put my foot on the clutch when it is going through a bad spell it will rev up perfectly but when i try and drive again its back to kangarooing down the road.
some days it doesn't play up at all, other days only does it for a few seconds. my gf has had it happen so bad when she was driving it that it actually stopped completely twice, restarted immediately.
very intermittent.
Old Mar 24, 2006 | 07:43 PM
nomiseel's Avatar
nomiseel
SOUND S LIKE THE AIR FLOW MASS METER CHECK YOUR WORK SHOP MANUEL ,I AM A DIESEL MAN MY SELF . HAD SAME PROBLEM WITH A NISSAN MICRA .YOUR LOCAL MOTOR FACTORS SHOULD STOCK THIS ITEM . BEFORE YOU START JUST CHECK THE BASICS PLUGS ,AIR FILTER BUT AT A GUESS YOUR DISCRIPTION SOUNDS VERY MUCH LIKE THE MASS MATER . HOPE THIS HELPS
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
