Help needed t2/t25 gurus please
Old May 1, 2011 | 11:59 AM
Martboy21's Avatar
Martboy21
Default Help needed t2/t25 gurus please
Morning all...
First post on here and I'm begging for help?
I'm currently running a custom turbo setup on a 1.3 Nissan Micra ( I hear you laugh!! )
I'm using the stock t2 from the frst
I have both turbo designs
Just oil and oil and water
I've been reading about the t2/t25 hybrid conversion but after 3-4 days of searching I can't find the answers I need
Basically I'm wanting to keep the turbine housing (I think, the bit which bolts to the manifold and has exhaust elbow which has a/r 47 written on it, I don't want to change position of manifold or downpipe
Compressor housing has a/r 48 written on it
Now is it as simple as finding a t25 which has the ar 47 so it fits onto the turbine housing?
So what t25 fill fit please??
Does the a/r 47 have anything to do with the size of the compressor end that fits
So I need to get a t25
Take it apart like this
And I want to bolt it on here if that makes sense
I understand I may need to squeeze the spigot ring to turn the compressor housing and may need to redrill the actuator mounting points
I hope this all makes sense please please turbo gurus I need you help
The
Old May 1, 2011 | 02:25 PM
Martboy21's Avatar
Martboy21
Anyone ?
Old May 1, 2011 | 05:57 PM
Martboy21's Avatar
Martboy21
Bump
Old May 3, 2011 | 10:00 AM
Martboy21's Avatar
Martboy21
Cmon someone must know please
Old May 3, 2011 | 05:54 PM
Martboy21's Avatar
Martboy21
I just wanna know if a t25 with AR 0.47 on the turbine side will fit the t2 turbine housing
I've been searching for hours and days so anyone with any advice would be hugely appreciated,
I'm losing sleep over this!!! Lol
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
