stage 3
Old Apr 24, 2011 | 10:48 PM
gcfcos's Avatar
gcfcos
Default stage 3
hi all. need some help with speccing a turbo. currently running stage one on t3 but going to fit 500 cooler, dark greens and 3 bar map sensor etc. was thinking of going t34 route but drove my mates escos with standard t34 and seemed to have a hell of a lot of lagg. any suggestions? cheers
Old Apr 24, 2011 | 10:53 PM
KSA-Cossie's Avatar
KSA-Cossie
t34.48
Old Apr 25, 2011 | 12:03 AM
dazzle740's Avatar
dazzle740
Which saph do you have 2wd or 4x4?, I only ask because if you have the 2wd you could try changing your exhaust manifold as well as this helps reduce lag and also removes the need for the turbo damper.
Old Apr 25, 2011 | 07:38 AM
You will get a shed load less lag and more off boost power with having it mapped, as opposed to a chip install ime.
If you do go this route plan ahead and consider if you are likely to want future upgrades, then ditch the dark greens and go straight to greys or similar, with as said a T34.48, will get you to around 370bhp, and be very lag free.
My own car starts to pick up around 1400rpm on boost but full boost is by 2500rpm, I run a hybrid T3/34, that is a T3 compressor housing machined out to take the T34 trim, brings in the boost earlier, but limits overall compared with full size T34.
If you're that worried about lag use a BB turbo, as this will virtually eliminate it, which to my mind would spoil the car, but if that's what you want ?
Old Apr 25, 2011 | 07:57 AM
AJC's Avatar
AJC
Good advice
Old Apr 26, 2011 | 08:32 PM
gcfcos's Avatar
gcfcos
cheers guys. its a standard engine, albeit low mileage so dont wanna kill it. would 370bhp with greys be too much for a standard engine? also how much is mapping? thanks, gary.
Old Apr 26, 2011 | 08:37 PM
Staffi's Avatar
Staffi
370 on Greys will be fine on your engine, i had that setup on my 3dr 4yrs ago on a T34.48 NMS Live map, great road car that was..
Old Apr 26, 2011 | 08:43 PM
gcfcos's Avatar
gcfcos
oh forgot ive fitted a group a headgasket too for good measure!! it might be best then to fit the t34 .48 and the greys. ive heard the live mapping is seriously expensive? plus i dont think theres anyone near me to do it but may be worth the travel. its currently 4wd but im converting to 2wd asap. will they check fuel pressure etc while mapping?
Old Apr 26, 2011 | 08:47 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
so wot is all is needed to see the 370?
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
