Rebuilt SCS 400/400 YBT complete engine/ecu
Fully Rebuilt SCS 400/400 spec from top to bottom.
The engine is ready to install and run,L8 pectel ECU,jetted amal valve also supplied as are the ancilliaries such as P/s,altenator,belts.
Its ready to plug and play,and will make a reliable track engine or a great road engine.
It Was built/dynoed on the SCS dyno @ 406.5 BHP/402 FT/IB with full dyno charts back in '04' and after 30k miles we have fully rebuilt it,so its a totally fresh engine with everything replaced.
Spec:
.New 7.6-1 comp Mahle pistons with valve cutouts,new rings. .5 overbore
.Fully rebuilt polished and ported Nick Waples head with new guides,seals
.SCS cams
.Polished crank with new bearngs
.New genuine INA tappets
.16 New ISKY valve springs (Normally 8 are only fitted.)
.Mountune WRC Head gasket
.WRC 6 stud block
.T34 .63 turbo,360 bearing -31 act
.Big wing baffled sump-4.5 ltr
.Kent adj vernier pulleys
.403 Grey injectors
.New genuine Ford Dizzy/Leads
Transmission:
.Alcon 6 paddle relined clutch kit
.Rebuilt front Diff
Spec:
.SCS cams
.WRC 6 stud block
.403 Grey injectors
Transmission:
.Rebuilt front Diff
The engine was running perfect but I decided to use it in a westfield or DAX and decided to rebuild it for that but a change of plan again sees it surplus to requirements.
It came out of my saff 4x4 originally
Mc5506
Oct 5, 2015 09:57 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Steve Escos
Oct 1, 2015 06:57 AM
