Ford Puma Discuss the Ford Puma here!
2.0 zetec engine into puma
Old Mar 28, 2011 | 10:12 PM
moondustka's Avatar
moondustka
Boooost!
Default 2.0 zetec engine into puma
I have searched the internet for days now, and a little bored lol
Does anyone know what engine mount is needed to fit a 2.0 blacktop zetec into a puma?
It's similar to the focus, but just not similar enough?
Thanks!
Old Mar 28, 2011 | 10:34 PM
Escow-Van's Avatar
Escow-Van
I'm not sure there is a suitable Ford one. Out of interest, why a 2.0 black top? The proper puma engine is only 5 bhp down on paper, a few more one torque, but is all ally and should use mostly the same mounts as another zetec SE (I guess its the 1.4 or 1.6, else I don't understand the need for a swap ).
Edit; looking at the state of your Ka, is Zetec turbo the reason?
Old Mar 28, 2011 | 11:00 PM
moondustka's Avatar
moondustka
Boooost!
Sadly the Ka has come to an end and everything is going into a puma
Suspension, brakes and wheels already swapped
So, yea I need to be able to mount the FRS lump!
Old Mar 29, 2011 | 09:26 AM
massivewangers's Avatar
massivewangers
I've been wondering about this, but there doesn't seem to be much info. My lass has a Puma and we want to fit a turbo silver top into it, just for some cheap fun, but not many people seem to swap engines. I don't fancy tuning the 1.7 myself!
Old Mar 29, 2011 | 12:06 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
track design not do a mount kit?
Old Mar 29, 2011 | 12:39 PM
bristol_fez's Avatar
bristol_fez
I am sure there is a bloke on here with a build thread who has mounted a 2.0 into a mk5 fiesta, might be worth having a look for the thread, think it is adamb or similar.
Old Mar 29, 2011 | 12:47 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
RE https://passionford.com/forum/restor...7-09-09-a.html
Old Mar 29, 2011 | 01:17 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
there isnt much info because very few people would bother with a low powered engine swap such as to a 2.0 NA zetec E over a 1.7 zetec SE. Pound for pound your money is better spent tuning the 1.7 engine and keeping the front end light compared to the extra weight of a Zetec E.
however a zetec turbo is a different proposition as the power/torque far outweighs the difficulties.
he fitted a 2.0 duratec.
Old Mar 29, 2011 | 01:48 PM
massivewangers
That's just it. With a pikey turbo conversion on a silver top, with a decomp plate, 200bhp is easily possible. To get that from the 1.7 would cost a fortune, and not have any torque by comparison. Especially as turbocharging seems a no-go on them really.
Welding in new mounts is no bother, seems a far better value option to give the car a kick up the arse than messing about tuning the 1.7 lump!
Old Mar 29, 2011 | 02:08 PM
Psycho Warren
Carbon Crazy
until you realise youve just fucked up the best part of the car ie the handling, by making the front end much heavier
And lets be honest, pikey turbo conversions on zetecs are not that reliable if you want good torque and drivability anyway.
Old Mar 29, 2011 | 03:19 PM
massivewangers
With the right suspension I'm sure the car will still handle well. Just a case of getting the balance right. May end up a bit nose-heavy compared to standard as it will be stripped to the bare bones anyway, but will get round that with some development I'm sure.
It will only be pikey from the point of view of having a decomp plate. Boost won't be massive and management won't be scrimped on, so it will be ok. If it melts a bottom end or two, it won't exactly cost a fortune to replace them
Old Mar 30, 2011 | 10:03 PM
moondustka's Avatar
moondustka
Boooost!
Ka with the FRS lump was awesome at handling... never really understeered
So, this mount... how was that silvertop mounted? And do blacktops and silverstops mount the same?
I'm ok to make one, but I just want to make life a little easier where possible.. I did a lot of fabrication to get the engine into a Ka!!!
EDIT: silvertop uses that back mount, cvh style.. which is ok. Worked in the Ka, would rather go for the proper side mount this time.
I also want to keep power steering and A/C I think this can be done
Old Feb 23, 2012 | 04:50 PM
russ rs's Avatar
russ rs
Pumabuild dropped a rs lump in a puma
Old Jun 4, 2012 | 10:55 AM
MrJayware's Avatar
MrJayware
Originally Posted by Ollie MK5 Turbo
That looks well smart!
Old Jul 25, 2012 | 03:30 AM
Straight_4_N/a's Avatar
Straight_4_N/a
SHUT THE HELL UP YOU KNOW NOTHING!!!!!!!!
The zetec-r engine is less than 20kgs heavyer than the zetec-se engine!
Not reliable bull unless you try to put to much power in the block.
Old Jul 25, 2012 | 03:37 AM
Straight_4_N/a
He knows nothing the weight diffrence between the two engines is nothing.
Easyest thing to do is get the focus mount and with the engine in, level up the engine then mark on the mount where you need to cut down the focus mount to make it level then just drill it and fit it into the car.
Gearbox wise you can keep you std gearbox if you use the focus 1.8 ib5 bellhousing on the puma gearbox. (the ib5 can easly take frs power)
JoeyBoyden
Jan 4, 2024 02:36 PM
Toms Grende
13
Aug 22, 2015 03:39 PM
