PATS Key Sensor Wiring
Old Mar 28, 2011 | 01:10 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Default PATS Key Sensor Wiring
Righto, I've got the key receiver thingy, the key and corresponding ECU from a dead Mk6 escort.
Happy days?
Well, no.
I had to cut the key sensor ring thingy out - the scrappy dude was literaly about to cube the car (I'd robbed the other bits earlier) so no time to do it nicely.
The delimna: the sensor has four BLACK wires coming out of its plug. That is all. No colours, no key stripes.
Err... does anyone have a pinout for the connector/plug???
Old Mar 28, 2011 | 06:19 PM
tezza68's Avatar
tezza68
Happy days?
Well, no.
Is this any use to you ??
Old Mar 29, 2011 | 08:06 AM
dunketh's Avatar
dunketh
Thanks!
Thats the most help I've had on this topic so far, after asking on many forums and beating the piss out of google on the subject.
I dont suppose you have a key for the number codes mean on that diagram?
Also, if its not asking too much, the transceiver has four wires on the diagram, as it does in real life. I can read a number '2' I dont suppose you know the numbers of the other three wires? I cant make them out.
Using your diagram I can at least isolate which wires from the loom I need to use. It looks like only three go to the ECU and no2 is either earth or warning light?
Thanks again.
Edit:
GOT PINOUT!!!
http://focusfanatics.com/forum/showthread.php?t=168281
Old Mar 29, 2011 | 07:51 PM
tezza68's Avatar
tezza68
Thanks!
Thanks again.
Edit:
GOT PINOUT!!!
From left to right
pin 4.... pin3....pin 1
Here is a pic of the pats plug
DixieTheKid
11
Jun 6, 2020 11:20 AM
Flatlinedan
Sep 18, 2015 12:41 PM
NC53
Sep 13, 2015 03:05 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
