Im just about to fit a hydraulic hanbrake some pics please
Old Mar 26, 2011 | 07:27 PM
rscos2004's Avatar
rscos2004
Default Im just about to fit a hydraulic hanbrake some pics please
As above changed all my brakes and need to fit a hydraulic handbrake but unsure on piping it up as im going to have no cable handbrake all info and pics would be appreciated cheers.
Old Mar 26, 2011 | 07:48 PM
Is it a ROAD car ?, if so hydraulic handbrake is a big no no, it has to be mechanical, or it will fail MOT.
Old Mar 26, 2011 | 08:54 PM
rscos2004's Avatar
rscos2004
It is a road car but ive fitted vxr8 front and rear brakes which probably would have handbrake shoes but im just using a hyd h/brake and maybe fit a cable to it to keep mot men happy.
Old Mar 27, 2011 | 08:47 AM
JonathanJ's Avatar
JonathanJ
Trouble is the cable is checked for operation during the test and that the compensator is working within its limits , I know what you are saying the old 106 rally school cars had no cable attached as they were just for off road , but the Ibiza I helped to run still had a cable and the plan was just to tighten it up when mot time came , but normally it would be slackened off to allow the hydraulic side to work first .
Piping is easy as long as you have a front / back split system as you just run the pipes in board , cut the single pipe and feed that into a sealed master cylinder then take the output out from the piston actuated end , all you are doing is when you pull the lever you are blocking the feed and pressurising the rear system .
If you have a differently split system then it becomes harder as you either need to use two hb master cylinders if still have abs , or loose the split and T piece them together in front of the single mc if not got abs .
Would think this might need a bit of "out of the box" thinking to sort it safely , would of thought some other calipers would of been a better long term choice tbh.
Old Mar 27, 2011 | 01:01 PM
rscos2004's Avatar
rscos2004
Ok ive binned the abs the calipers ive fitted are ap with 360mm discs front and 330mm rear so i think you wouldnt get a lot better without paying mega money cheers.
JoeyBoyden
Jan 4, 2024 02:36 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
