2wd T5 gearbox rebuild
I,m looking at getting this done over the coming months and most likely the diff too , how much is a working but tired gearbox going to roughly cost to rebuild/recondition ? Mine is in working order (just about) and being as the engine is coming out soon , now is the best time . Does anywhere stock recon units for exchange too?
Many thanks
Mike
Many thanks
Mike
Many thanks
Mike
Many thanks
Mike
Hiya Mike i posted same question last week on here BARA is the best place for box an they do diff's too
A basic bearing and seal replacement will be in the region of Ł350. Or a full recon unit on an exchange basis is around Ł650. Or at least thats what I was qouted.
Hi Mike,
My gearbox was Ł580, but everything that could be worn was worn, needing synchro on all 5 gears, a normal build is about Ł350 from the peeps I use, they also do diffs, although there is a ace place in Kent not far from dartford that does diff rebuilds/mods.
Cheers Tabs , I,m unsure how bad mine is tbh , have no trouble finding gears but the lever is sloppy , its fairly whinny and the thrust bearing needs replacing . Its also effecting the 'feel' of a cossie
If it's whiney it's on borrowed time, the lever mechanism is likely worn for the slop to be there.
At the base of the lever mechanism there is a ball/socket joint, this wears over time, but there is a 100% perfect cure, that's not expensive either.
TPM961
Jan 15, 2018 10:50 AM
