Oil feed. T4 onto 4x4 head help!
Old Mar 20, 2011 | 05:06 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Default Oil feed. T4 onto 4x4 head help!
I need a oil feed hose for my T4 turbo. Bother is there isn't much room for the 90 bend between the head an turbo. So it has to be quite trim. The standard 4x4 hose fits the connection but is too short. I'd buy one of these ones with the filter included but dont know if the bend will be tight enough to fit etc. Anyone have a solution for me?
thanks
Old Mar 20, 2011 | 06:41 PM
Banjo bolt and fitting ?, can get in all different angles.
Old Mar 20, 2011 | 06:48 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
I am switching to the 2wd style on my t4 ,4x4 saph .
Old Mar 20, 2011 | 06:52 PM
Dicko&Vacant's Avatar
Dicko&Vacant
the standard 4x4 oil feed hose does fit mate? well it did on my t4 powered 4x4 cossie
Old Mar 20, 2011 | 07:52 PM
B13 JUS's Avatar
B13 JUS
just blank the head of and convert it to the same as 2wd's from the other side of the block.
you get a better oil supply from there
Old Mar 20, 2011 | 08:00 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Where does the 2wd feed come from? Any pics?
Old Mar 20, 2011 | 09:53 PM
Nash's Avatar
Nash
Cake lover!
Feeds from where your standard pressure switch is under the inlet.
Old Mar 21, 2011 | 08:49 AM
B13 JUS's Avatar
B13 JUS
There's an adaptor that screws into your block for oil pressure switch, a 2wd adaptor has a oil feed take off.
Old Mar 21, 2011 | 06:03 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
ah. thats a no-go i'm afraid. Switch is already fouling the filter because the take off for the pressure gauge sits there
Old Mar 28, 2011 | 08:37 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Does anyone know where i can get the adaptor for my oil feed to runn 2wd feed? Also a blanker for the 4x4 oil feed on head??
Old Mar 28, 2011 | 08:57 PM
little bram's Avatar
little bram
the oil feed pipe does fit mate like dicko has said. we have also fitted one
Old Mar 29, 2011 | 07:45 AM
carl/saff's Avatar
carl/saff
i used these
Fitted like this-with stack oil pressure gauge fitting
Burtons sell the fittings .
hope that helps .
Old Mar 29, 2011 | 08:28 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Carl/saff Thanks alot this was as helpfull as it gets!
Pint on mee
Old Mar 30, 2011 | 11:51 PM
ram's Avatar
ram
Has a large member
Hi mate, i can make you up a custom pipe with earls fittings and inline filter to whatever length and fittings you need if that helps
Heres my set up below..
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
mint_s2
Sep 2, 2015 08:58 AM
