plz help before i put a hammer to it
Old Mar 18, 2011 | 08:13 PM
chigwellboy's Avatar
chigwellboy
Unhappy plz help before i put a hammer to it
hi can anyone help i brought a d reg s2 with 1.8 zvh on way home at good next day open the bonnet and it was covered in cum engine was f**ked so i got turbo 1.6 cvh put it in the car got it up and running. Took it up and down the park a few times and it was going sick, parked it on the drive, next day i stared it up and took it down the road and it would not boost it made all the noises but kept pulling back, someone said the turbo was blown so i brought , put it on, and guess what it done the same thing but this timethe exhaust manafold glowing orange. plz hel;p as my wife is threatening to divorce me if i spend anymore money.
Old Mar 18, 2011 | 08:28 PM
bythomson's Avatar
bythomson
welcome to the world or rs turbos, lol , thats just the way they are mate but oce you get the niggles sorted out you'll be wondering what all the fuss was about,
sounds like either misfiring or mis timed, or stuck valves letting fuel ir mix ignite in manifold, maybe someone with more experince will have better answer ,
might be worth taking it to garage for straight answer , might be more money out in short term but saves chasing around for the problem
Old Mar 18, 2011 | 08:41 PM
chigwellboy
tthanks for your advise
Old Mar 18, 2011 | 09:11 PM
JonathanJ's Avatar
JonathanJ
Hi , is it running the std MFI engine or has it been changed to EFI , if it still has a distributor then sounds like the timing is well retarded and causing the glowing exhaust and the lack of power have you had it set up and has the cam timing been checked ?
Old Mar 18, 2011 | 09:59 PM
martysmartie's Avatar
martysmartie
As said check the timing, when you say holding back do you mean misfire etc or it just lacks power? Also as said is it MFI or EFI?
EDIT: Forgot also check the fuel filter, this IS a servicable item!
Martin
Old Mar 18, 2011 | 10:03 PM
chigwellboy
its MFI it does not misfire its lack of power on boost, makes all the noises but no go its feels like im in a 1.3. The manifold is glowing red after 5 mins of use.
Old Mar 18, 2011 | 10:04 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
get it looked at by someone local who knows rst's
not always a garage, just an owner
timing etc needs to be right and camtiming too, it could be too much boost for the ecu
soon as it hits the limit its cutting back, if its got a bleed valve wind it right in to lower boost and see if it helps
could be a million things tho, sensors, hoses, leaks, wrong piping up
Old Mar 18, 2011 | 10:05 PM
JonathanJ's Avatar
JonathanJ
would get cam timing checked and ignition timing checked after that , sounds like one or both is out
DixieTheKid
11
Jun 6, 2020 11:20 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
Cossikev
Sep 13, 2015 02:00 PM
marky_g
Sep 12, 2015 04:26 PM
hopper350
Sep 4, 2015 12:53 AM
