Various Cossie spares, plus other car bits. massive clearout!
Old Mar 15, 2011 | 09:28 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default Various Cossie spares, plus other car bits. massive clearout!
hi all, having a clearout as i want to demolish my garage this year! here are the first few items, i'll update as i clear more out
2WD alternator (twin belt one), been sitting a long time, but turns fine: £30
3x cam/dizzy pulleys marked KA: £3 each
2x 2wd water pump pulleys (twin bent ones): £5 each
2x distributor shaft seal housings (the one behind the pulley with the oil seal in it): £5 each
distributor drive (& fuel pump drive on pinto) shaft: £5
2x 2wd fuel rail and regulator:£15
Power steering pump bracket (2wd):£10
4wd pistons, standard size. no rings. one is about 2 thou down from the rest, may sell induvidually if people want them: £40 for the set.
brand new 4wd engine mounting arms: £20 the pair.
4wd diff brackets, brand new: £10 the pair.
4wd sump with shaft, dirty. £40
Sapphire rear jacking point cover, numbers read I.ET.644. £10
6122486 wiper arm, may be escos?: £5
L6 ecu, removed from my sapphire about 5 years ago, no chip: £50
Loom for L6, also from my old sapphire: £50
2wd inlet manifold, no plenum. very clean: £15
oil pump hex drive £2
2wd throttle bracket £5
xr4x4/cossie 4wd gearbox. front casing missing. all gears good! great for spares or to replace your broken one: £60
Front oil seal housing, slight damage, but it wont affect anything at all: £7
12mm plenum spacer: £20
Map sensor bracket: £5
Ignition module and bracket: £10
Group A coil: £20
2x cosworth 2wd dipstick and tube: £7 each
2wd thermostat housing/elbow: £7
2x breather tank (one that goes on the block): £5 each
Cosworth 2wd scrap head, good for mocking up or throw it on a pinto block to make a 'cossie table' £20
Cosworth 4wd PAS pump and bracket, multi 'v' type: £20
2x 2wd PAS pumps: £15 each
2x PAS resevoirs: £3 each
Clutch arm - not sure if its 2 or 4wd: £10
2wd Water pump to heater matrix pipe: £5
Cossie twin fans - work well!: £30
Cossie 2wd hubs: £20 the pair
4WD Cossie front AVO Coilovers, need recon: £90 the pair.
xr4x4/cossie gearbox. no front housing, was used for a v6 2wd box. all gears look good: £50
onto non-cossie stuff:
xr3 pipercross panel filter, MFi. £5
nissan pulsar GTiR 45mm throttle bodies including injectors: £80
auto specialists xr3i sill plates, never fitted:£10
Steering wheel, unknown make: £10
Zetec ST170 pistons and rods: £40.
thats all for now! prices do NOT include postage. paypal or cash are best methods of payment
Old Mar 15, 2011 | 09:49 PM
Sharkey's Avatar
Sharkey
PM Sent
Old Mar 15, 2011 | 10:05 PM
m4rkl's Avatar
m4rkl
which side is the jacking point cover for?
if its n/s/r ill take it
Old Mar 15, 2011 | 11:26 PM
Turbo Zetec
Engine Machinist
no idea at all, thats why i put the numbers on for now
will fit it onto some skirts i have tomorrow to see if i can work it out
replied to PM's
Old Mar 15, 2011 | 11:41 PM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
pm'd cheers
Old Mar 16, 2011 | 06:21 AM
garrett's Avatar
garrett
pm send
Old Mar 16, 2011 | 06:48 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
ill take the jacking point cover mate how do you want paying?
Old Mar 16, 2011 | 07:19 AM
rich123's Avatar
rich123
hi ill have the thermostat housing pm'ed
Old Mar 16, 2011 | 02:02 PM
Sharkey's Avatar
Sharkey
Payment has been sent Mark
Thanks
Old Mar 16, 2011 | 06:50 PM
Turbo Zetec
Engine Machinist
replied to all PM's. and updated thread.
Old Mar 21, 2011 | 06:26 PM
Turbo Zetec
Engine Machinist
lots more added today
Old Mar 21, 2011 | 07:03 PM
peteh's Avatar
peteh
in the box of bits, you havent got a decent tank-power steering pump hose have you?
the one that's got quite an twist in it, can see two in the box i think, mine's all perished that's all.
Old Mar 21, 2011 | 07:12 PM
RS SHAUN's Avatar
RS SHAUN
I'll have a breather tank, that goes on the block(under the inlet) please!
Posted?
Paypal ok?
Cheers shaun
Old Mar 21, 2011 | 09:29 PM
Turbo Zetec
Engine Machinist
will have a look tomorrow for you
Old Mar 21, 2011 | 09:52 PM
RS SHAUN's Avatar
RS SHAUN
Payment sent martin
Old Mar 21, 2011 | 09:57 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
whys the 2wd head scrap mate any damage to it? how much to post it to ka18 4qp?
Old Mar 21, 2011 | 10:46 PM
peteh's Avatar
peteh
thank you!
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
nuttynil
Shows & Track Days
Jul 31, 2015 10:07 PM
