efi 1.6 rs turbo sensor help, rough running issue
Old Mar 14, 2011 | 05:51 PM
base190380's Avatar
base190380
Default efi 1.6 rs turbo sensor help, rough running issue
hi there i have a 1989 rs turbo cvh efi, but when its started from cold for maybe the first minute it runs a bit spluttery, once warmed up no issue at all, does anyone no wot this could be? maybe the water temp sensor in inlet manifold? also noticed sometime when warm and you let foot offf the pedal, on decelaration you get a bit of backfiring.
Old Mar 15, 2011 | 10:51 AM
Is the ignition timing adjustable ?, check this then check for any air leaks on the inlet side.
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
