Mk1 Focus Brakes
Old Mar 13, 2011 | 05:29 PM
blackcossie's Avatar
blackcossie
Question Mk1 Focus Brakes
The girlfriend was driving down the road and came to brake and the pedal went straight to the floor with no resistance. I changed the master cylinder and it made no difference so i changed the servo, both these parts where from my local scrap yard. The car now has a brake but it is alittle spongy so i have bled it again and again but their is no air coming out now. The system does not seem to have any fluid leaks but like I say its spongy. the car is a Focus 1600 zetec on a 02 plate with 100,000miles
Any ideas please
Old Mar 13, 2011 | 05:56 PM
I assume as you don't mention it the car has no abs ?
I would start by bleeding the master cylinder, to ensure no trapped air is there, then if ok clamp all four brake pipes at the wheels on the flexy pipes, see what the pedal is like, it should be very hard, release one clamp at a time, and try the pedal, it will go sloppy when the duff one is released.
If the car has rear drums ?, look at the e brake adjustment first, another trick is to apply the e brake and then see what the pedal is like, if then a lot better it is almost certainly e brake adjustment is out.
Old Mar 17, 2011 | 08:14 PM
blackcossie
cheers I'll give it a go.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Ben26
Aug 27, 2015 08:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
