Fuel pump symptoms? or something less Synister
Old Mar 10, 2011 | 09:11 PM
actionfighter's Avatar
actionfighter
Default Fuel pump symptoms? or something less Synister
I Posted this Yesterday but no joy yet,my car (tdci Mondeo ghia x)
is after having injectors reconditioned and recoded,fuel tank drained and new filter put on,my mechanic eventually got it started(it was airlocked) and all seemed good plenty power no problems starting and drove home perfectly,it started first tip in the morning,drove about 15/20 miles and died in the middle of the road.
No way would it start so i towed it home,it started first tip when i got home and then died five miles down the road again,so its basically running perfect for a while then stalling and not starting for around 10 minutes,then perfect again
Does this sound like the fuel pump?
I drove it back to the mechanic this evening and on a straight it hit 100 mph with ease! surely this must be something small (I also changed the cam position sensor) any ideas???
Old Mar 10, 2011 | 09:24 PM
Icurus's Avatar
Icurus
Sounds electrical. Re-check the wiring to sensers etc.
Old Mar 10, 2011 | 09:51 PM
actionfighter
I like the sound of that,sounds cheaper than a pump
Old Mar 10, 2011 | 10:03 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
What fault codes come up now? It could be any one of a hundred things, so you need to narrow it down before looking for the solution.
Finger's crossed it's something simple.
Old Mar 10, 2011 | 10:19 PM
Sp3no's Avatar
Sp3no
I had this on a previous car and it was the immobilisor playing up
Old Mar 11, 2011 | 09:24 AM
actionfighter
Getting it read today I'll post up the codes if they show up
My mechanic mentioned the immobiliser aswell
Fingers crossed
Old Mar 15, 2011 | 05:45 PM
actionfighter
seems like everything is finally sorted (again) we changed the crank position sensor as it showed up on diag report and all is good for the last few days,im slowly getting my confidence back with her and its doing between 45 and 48 mpg's with loads of power!! well happy thanks for everyone's help
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
