Can you buy wheel bearing dust seals on thier own? where from?
Old Mar 9, 2011 | 04:14 PM
M K's Avatar
M K
Default Can you buy wheel bearing dust seals on thier own? where from?
I have removed my new 4x4 front wheel bearings from the hubs as they had to be fitted when the car was in its dummy build stage, now i want the hubs blasted and coated hence the need to take them out,
Problem is one of the seals is battered and is no good to re use and as the bearings are new im not buying a whole new kit just for the seal so where if possible can i get one from?
This is a pic of the type of seal im after, its 68mm id and 70mm od but i forgot to get the thickness
Thanks
Marc
Old Mar 10, 2011 | 10:45 AM
M K's Avatar
M K
Just to let anybody else know who may be interested, i have been assured you can get these from fords still
Old Mar 10, 2011 | 11:32 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
Thanks
Marc
hi marc i think you need to mearsure again ,ones you have only make it 1mm thick
Old Mar 10, 2011 | 11:46 AM
M K's Avatar
M K
will double check it
malkiemac3579
Jul 14, 2017 12:10 PM
rog
Aug 30, 2015 05:32 PM
borboyous
Aug 22, 2015 11:17 AM
pegaz
Aug 12, 2015 07:30 AM
muz
Aug 1, 2015 06:48 AM
