how to remove this vr6 rotor arm??
The cure to stop this is to grease the dizzy shaft prior to fitting, even ford ones can get jammed, but usual problem for them is wiggly rotors, as the slot can be too large for the rotor arms notch, I then just use a bit of cereal box card between the rotor arm and dizzy shaft.
All cars I have ever come across the rotor arm pulls off the shaft and that looks no different, I do as said above though grease the shaft before I fit a new one, have you tried gently wiggling up and down on each side? patience is a virtue
Martin
Martin
rsguy
44
Sep 29, 2015 03:29 PM
Fudgey
Sep 17, 2015 01:06 PM
