Chip help
Old Mar 8, 2011 | 06:09 PM
1stcoz's Avatar
1stcoz
Default Chip help
Hi this is my 1st cosworth and im trying to put my new chip in but cover want go on as the chip is to big (HELP ME PLZ)
Thanks John
Old Mar 8, 2011 | 06:11 PM
oldford's Avatar
oldford
Most likely a wrong chip then.
What type of ecu is it? L1, L6, L8, P8? Check: http://bigturbo.co.uk/main1.htm
Who manufactured the chip? Maybe add a photo?
Old Mar 8, 2011 | 06:33 PM
1stcoz's Avatar
1stcoz
Its a l8 from a 4X4.
Old Mar 8, 2011 | 06:38 PM
1stcoz's Avatar
1stcoz
Its a L8 from a 4X4. How can i add photo.
Old Mar 8, 2011 | 07:26 PM
martysmartie's Avatar
martysmartie
LOL then it's not the chip it should be if that at all, the chip is a rectangular shape and has alot of legs, this simply sits in a socket on the PCB and then the cover screws in via 4 screws.
To post the image you need to have it stored online and then you post the link to the image using [IMG] coding.
Martin
Old Mar 8, 2011 | 08:27 PM
1stcoz's Avatar
1stcoz
Ok i think this how to do it..
<a href="http://www.flickr.com/photos/59696061@N02/5510439604/" title="new on left by JChannon, on Flickr"><img src="http://farm6.static.flickr.com/5097/...f92954f01c.jpg" width="500" height="333" alt="new on left" /></a>
Old Mar 8, 2011 | 08:31 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Looks to me like it should fit just fine.
In what way is it too big?
Old Mar 8, 2011 | 08:35 PM
1stcoz's Avatar
1stcoz
Its to high the lid sits up by a good 5mm
Old Mar 8, 2011 | 08:37 PM
martysmartie
Is the "New on left" the Evolution chip on top of the Superchip for size comparison or is the one on the left the new chip itself?
Martin
Chip's Avatar
Chip
Well what help do you want then if thats what happens?
Either cut a hole in the lid or get another chip, i'd be going for the later personally.
Surprised Stu would supply something that doesnt fit, there must be some misunderstanding somewhere I would think. Phone him tomorrow.
Old Mar 8, 2011 | 08:41 PM
1stcoz's Avatar
1stcoz
Yes new one on the left. I was thinking i would have to take some think out to make it fit. I will have to contact them and see what they think.
Old Mar 9, 2011 | 07:26 AM
Stu @ M Developments's Avatar
PassionFords Creator
Morning,
The chip should have been supplied with instructions explaining how to modify the ECU's daughterboard to facilitate fitment. Did you buy it new?
Old Mar 9, 2011 | 03:45 PM
1stcoz's Avatar
1stcoz
Hi i got the chip from you mate.
Its well big im going to have a look at the instructions to see if i missed something.
Old Mar 9, 2011 | 04:37 PM
Hi, Please accept my appologies if any of teh instruction sheets are missing.
Please E-Mail us with your chip number and we can email over any instructions that are missing sir.
Old Mar 9, 2011 | 04:51 PM
1stcoz's Avatar
1stcoz
The number on the chip is 5283.
Old Mar 9, 2011 | 05:34 PM
1stcoz's Avatar
1stcoz
Will the pistons i have found on ebay be ok for my sierra the Item number is 290536645333
Old Mar 9, 2011 | 09:12 PM
Chip's Avatar
Chip
Wiseco's are good pistons and RS200DELL is a good seller (derrick scarrow) but they are 7.8:1 so might not match that chip you just bought.
Old Mar 9, 2011 | 09:48 PM
1stcoz's Avatar
1stcoz
Hi i got Stewart Sanderson to help me out and he was very helpful. I have a gt35 turbo with external wastegate big intercooler and radiator and this what he told me to get and i did. I trust him 100%. See what you think.
Ok, top of my head, If I were to take a standard YB and make it suitable for your turbo and 400+BHP I would lower the compression to 7.8:1 with pocketed pistons, fit a 3 port breather system, ported head and cometic headgasket. Then we would fit an uprated intercooler and radiator, finally, you’re ready to bolt on these parts:
Necessities:
BD 16 inlet cam.
Double valve springs so we can rev her to 8000rpm.
New followers BECAUSE we are going to rev her to 8000rpm
Plenum spacer to improve airflow through the inlet trumpets.
Bosch 044 pump and adaptor to fit direct to your car.
Engine & gearbox mounts to stop movement wrecking your DS joints.
3 bar map sensor:
83lb injectors
Dump valve: (necessity for GT series turbos)
Chip to your own spec
Old Mar 9, 2011 | 09:50 PM
Chip's Avatar
Chip
Well then bearing that in mind, yes those pistons will be fine.
Old Mar 9, 2011 | 09:51 PM
Chip's Avatar
Chip
PS
and with that sort of money spent, I would be taking it back to Stu for a live map when its finished.
Old Mar 9, 2011 | 10:13 PM
1stcoz's Avatar
1stcoz
Hi he is in Blackpool and im in west sussex long way to go. Do you think i should do the con rods to. And is there a good and a bad valve set. Also looking for a complete gasket set. Could you help me with this.
Old Mar 9, 2011 | 10:25 PM
1stcoz's Avatar
1stcoz
Thanks John
Old Mar 9, 2011 | 10:27 PM
Chip's Avatar
Chip
Yes there are good and bad valves, good condition original ones are a very good option as they are high quality in the first place.
I'd do the drive if I were you, its worth it to get the car running right.
Standard rods should be fine if they are in good condition.
Get a WRC gasket, not worth messing around with anything else now they have come down in price.
Martin hadland is normally good for prices on those IIRC
Old Mar 9, 2011 | 10:32 PM
1stcoz's Avatar
1stcoz
Sorted saved some cash. I will have a look for them from Martin hadland. Thanks for all you help
Old Mar 10, 2011 | 05:56 PM
1stcoz's Avatar
1stcoz
Hi Im thinking your right mate i will be going to blackpool. Get it done right.
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
