Cosworth fuel pump re-wire braided looms
Old Mar 8, 2011 | 10:46 AM
Cossy Mike's Avatar
Cossy Mike
Default Cosworth fuel pump re-wire braided looms
Can anyone put a diagram up of how these wire up please?
(supposed to run through an existing relay or something)
I've heard they can be a nightmare to do and it's putting me off buying one.
Thanks
Old Mar 8, 2011 | 10:54 AM
JamesH's Avatar
JamesH
I got mine off a company called CW Looms
Old Mar 8, 2011 | 11:03 AM
Cossy Mike's Avatar
Cossy Mike
Yeah that's who I'll likely buy it from but I need to know how they wire in.
I've heard there a pain as they wire through an existing relay or something?
Can anyone advise or post a pic up of the diagram please?
Old Mar 8, 2011 | 11:09 AM
JamesH's Avatar
JamesH
From memory,
Live terminal from the battery (fused on the loom), then the relay on the loom will be in the boot, and you cut the original feed, crimp it, and put that onto the relay. Make a new earth and all done?
So the original feed to the pump switches the relay and gives power to the pump using the new direct feed from the battery
Old Mar 8, 2011 | 11:22 AM
Cossy Mike's Avatar
Cossy Mike
From memory,
So it sounds like 3 connections and it's done
does'nt sound to hard then
Old Mar 8, 2011 | 11:29 AM
JamesH's Avatar
JamesH
Much easier than wiring it yourself like I originally did Much neater too
Old Mar 10, 2011 | 11:32 AM
Cossy Mike's Avatar
Cossy Mike
as I can't find anyone that sells them apart from on ebay and he won't reply any emails!
Old Mar 10, 2011 | 12:16 PM
Rsmat's Avatar
Rsmat
I'm sure Daz c on here does them.
Old Mar 10, 2011 | 12:27 PM
JamesH's Avatar
JamesH
Mike,
I can get you one done next week I expect, but the guy is on holiday this week
Old Mar 10, 2011 | 12:31 PM
Cossy Mike's Avatar
Cossy Mike
Mike,
Can he do them with the relay under the dash rather than in the boot?
Old Mar 10, 2011 | 12:47 PM
JamesH's Avatar
JamesH
I'm sure he could do yes I believe the original live comes from the ECU anyway so would just be a case of cutting it there instead of the boot
Old Mar 10, 2011 | 01:01 PM
Phil2002's Avatar
Phil2002
neg switch comes from ecu, live still comes direct from battery as standard but runs through a fusable link that after 20 odd years will be corroded and shitty. I made my own and put the relay up the front in the original postion.
Phil
Old Mar 10, 2011 | 01:13 PM
Phil2002's Avatar
Phil2002
Buy a new 40amp relay. The relay will have terminals 85, 86, 30 and 87. you may be left with one terminal (87a) don't panic you don't need it
blue/white from ecu(pin28 i think from memory) - pin 85
ignition feed - pin 86
Fused supply straight from battery - pin 30
fuel pump + terminal- pin 87
the old ford black/red will also need to be connected to pin 87 as this also powers the iscv etc. make sure you isolate it boot end to prevent short circuit.
i used a Durite 40/70 amp relay part No. 0-728-70
hope this helps,
Phil
Old Mar 10, 2011 | 11:33 PM
Rob Virgo's Avatar
Rob Virgo
good info
Old Mar 11, 2011 | 07:24 AM
Cossy Mike's Avatar
Cossy Mike
hope this helps,
Phil
Yeah it does thanks
have some Green!
Old Mar 11, 2011 | 09:02 AM
BEN FRST's Avatar
BEN FRST
Ring Matt Lewis He has them on the shelf dead easy fit and come with insructions
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
