drying flood damaged car?
Old Mar 8, 2011 | 09:16 AM
geordiegooner's Avatar
geordiegooner
Default drying flood damaged car?
as above just bought a 05 plate car that has been water damaged(rain water only)whats the best way to dry it out.it suffered water upto roughly inner sill level and now condensation all over wiring,fusebox ect in interior.
Old Mar 8, 2011 | 09:22 AM
phil_focus's Avatar
phil_focus
strip the seats, carpets and any foam crap out as much as you can and hang it all up in a warm place. ideally need to get a heater in the car too with the windows open.
if you don't do that it'll take forever to get rid.
Old Mar 8, 2011 | 09:25 AM
geordiegooner
was thinking of stripping out dashboard too and spraying all wiring with something like wd40?
Old Mar 8, 2011 | 09:51 AM
rst in breaking's Avatar
rst in breaking
probally better with copper grease on terminals? can imagin it playing havoc with wiring in long run sadly, best of luck
Old Mar 8, 2011 | 10:05 AM
tommytwotanks's Avatar
tommytwotanks
after stripping the car of carpets, seats door, cards and anything else that might be damp what about hiring a dehumidifier, you could buy one as they are not that dear
tommy
Old Mar 8, 2011 | 10:24 AM
dojj's Avatar
dojj
Resident Wrestling Legend
You need to air the car out and stuck some sort of air coditioner into it to dry up all the mosture. Getting the interior out will get rid of most of the moisture and then you dry the rest of it out but it's a lot of hassle if things get fucked up along the line.
Old Mar 8, 2011 | 10:52 AM
Cossy Mike's Avatar
Cossy Mike
De-humidifyer?
plug it in and leave it inside.
All fabric would need cleaning I would have thought as it'll stink in the summer
Old Mar 8, 2011 | 12:12 PM
vaughant's Avatar
vaughant
If it were me I'd pull the fusebox out etc and shove it in the airing cupboard etc,pull all connectors and put electric grease on them,any contact cleaner etc.I'd avoid wd40 as it's sometimes a bit too oily for electrical work.
I'd be amazed if you get much bother with it though,most electrics are pretty tough,and disposable really,up to sills is fuck all.
Old Mar 8, 2011 | 12:24 PM
geordiegooner
all lights wipers horn ect work fine and it started first time off the key,its a bit strange because most water was either in rear footwells or spare wheel well.i took all rubber bungs out of sills ect and there was no water in the.ive got a vax washer so all seats carpet ect will be washed with this and then dried out.was very clean water that came out of spare wheel well but till i get in touch withg previous owner i wont know what happened to it.
Old Mar 8, 2011 | 01:00 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
if its only up to the inner sills then only carpets should be saturated, but youll want seats and door cards out too to dry all the condensation and damp.
Old Mar 8, 2011 | 02:24 PM
geordiegooner
yeh all the interior is coming out to get cleaned first
Old Mar 8, 2011 | 04:43 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
pull the interior out ,
if you know someone with a spray boot have them put it in on a low heat bake for a cpl hours
should dry out all the areas you cannot reach ?
Old Mar 8, 2011 | 05:48 PM
left hooker's Avatar
left hooker
put a De-humidifyer in it it will pull all the water out as i have done it to my car when it had a water leak and was soaked inside bone dry now
Old Mar 8, 2011 | 06:52 PM
matts1's Avatar
matts1
what about pullies on the bay? bearing etc, would it be worth taking a close look at these, depending how it was angled when flooded it could have sat nose in?
Just a thought incase you get issues down the line from things drying up.
Old Mar 8, 2011 | 07:49 PM
dingla rs's Avatar
dingla rs
we had two were i use work ,if it still runs and has aircon turn that on ,we left them running alday soon sorts them or as a bove dehumidifier
Old Mar 8, 2011 | 07:53 PM
geordiegooner
front footwell is bone dry its more rear footwells and spare tyre wheel well had about 4" of water in.water was very clear water in spare wheel well.
j.hammond1
30
Oct 31, 2021 05:28 PM
Botts
Aug 13, 2015 04:16 PM
dal3door
Aug 13, 2015 06:55 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
