3 door tyre size
hi all
ive got some compomotive 5 spokes for my 3 door that im getting refurbed tommorow and was wondering what tyre size i could get away with on them they are 8x17's i dont want to do any trimming of the arch kit if possible or if not very little trimming, its been converted to 4wd so front and rear sizes will have to match, the wheels are et35 iirc its also got coilovers so i can set the hieght to suit
i was thinking 215/40/17 myself does anyone know if i can go wider?
cheers peeps
cheers peeps
really? never thought i could go that wide i had been told 225's may be ok
did you space your wheels out at all as im told they may "look" better spaced on the rear but tbh i want as much space for tyre as i can get!
how low did you run it?
looks really well that mate same wheels as i have, did you use longer wheel studs on the rear or was it not neccesary? mine have group a inserts, i allready have the nuts
btt
allthough i dont want to doubt you with your 235's ive been local rsoc night tonight and was told there aint a cat in hells chance id get more that a 215 without chopping arches! im confused.com and need some definitive advice before i order the best part of Ł400's worth of tyre!!
btt
The man that does my bodywork owns one, and has 235 with no modded arches either, although if he needed to of course that's no issue, why didn't he ?, it wasn't necessary!!
So with the right offset 235 no problem, I know 225/45 fit on my sapphy no problem as tried them, so using 225/45 front 235/45 rear, but don't suppose that helps as it's a 3 door.
If you need to run the same front and rear because of 4wd set up you will not get 235.40.17 under the front arches or you running different on the front, way have missed that bit?
i am 4wd so will need same front and rear looks like i may need to get the tape measure out and have a look!
Im running a 215.40.17 on the front of mine on a 7.5 inch wide rim with et35 offset and the fronts rubbed but only just
borboyous
Aug 22, 2015 11:17 AM
