Help needed
Old Mar 5, 2011 | 05:08 PM
archy's Avatar
archy
Default Help needed
Hey there guys got a major headache, i have an escort xr3i mk4 efi am getting rough idlewing and a flat spot causing judddering and hesitation at around 2500rpm in every gear despite doing full service plugs, leads, coil pack and filters change
Any ideas please help ggrrrrrrrrrrr
Old Mar 5, 2011 | 08:48 PM
tommytwotanks's Avatar
tommytwotanks
have you tried injector cleaner, a small bottle in halfords £1.99 goes in the tank next time you fill up
tommy
Old Mar 6, 2011 | 10:53 AM
archy's Avatar
archy
thanks for the reply yes have put redex injector cleaner through it with no difference even after 100 miles i am now starting to think maybe pressure regulator any 1 agree or have another suggestion
Old Mar 6, 2011 | 11:05 AM
st3v3's Avatar
st3v3
Checked your pipes for air leaks?
Old Mar 6, 2011 | 11:21 AM
archy's Avatar
archy
cheers mate yes have checked all the obvious even gave it full service but still no luck and now im just hitting a brick wall as to where to go next
Old Mar 6, 2011 | 11:34 AM
tommytwotanks
Default fiesta with sierra cossie running gear, awsome
sorry i cant delete it
Old Mar 6, 2011 | 11:55 AM
Tev's Avatar
Tev
sounds stupid but have you checked the fuse box? i had a mk5 escort that showed all the issues you are suffering from, i changed everything including air flow meter,coil pack leads,plugs fuel fileter, turned out to be problems with the fuse box
Old Mar 6, 2011 | 05:28 PM
archy's Avatar
archy
hadnt actually thought of that tev lol seems to be a fuelling problem as if lack of fuel yet running mega rich at the same time 100 miles to half tank ouch
Old Mar 6, 2011 | 05:55 PM
archy's Avatar
archy
what problems with the fuse box did you have ??? give an idea what to look for lol
Old Mar 6, 2011 | 06:41 PM
Tev's Avatar
Tev
kinda hard to explain but the wire's leading to the fuses break down, my fuel pump stopped working i had to take power from the next fuse to get home turns out its a common problem, i just replace the fuse box n it cured everything
Old Mar 6, 2011 | 07:02 PM
archy's Avatar
archy
well heading up the breakers yard next week going to get fuel pressure regulator fuel pump at my mates advise and at tevs advise fuse box try 1 at a time and see if can cure the problem will update end of next week as to wether the problem is solved
However in the meantime ANY ADVISE is more than welcome
Old Mar 8, 2011 | 05:46 PM
archy's Avatar
archy
BUMP bump
Old Mar 11, 2011 | 05:13 PM
archy's Avatar
archy
BUMP BUMP
Old Mar 12, 2011 | 08:49 PM
archy's Avatar
archy
Default help me pleeeeeease!!!!
hey guys still in urgent need of help to get my motor running right please please please any help very welcome
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
