B&W T-5 shift ... ???
Old Mar 4, 2011 | 03:15 PM
2wd's Avatar
2wd
Default B&W T-5 shift ... ???
Hi .. about quickshifts for the B&W T-5 .. I've heard alot good and bad about it... but what is the opinion about this here and if you should have one ...witch one would be the best ??
Reason for asking is that the org shift is proberly broken and it seems hard to find a new OE one
Old Mar 4, 2011 | 04:11 PM
cossytonyt's Avatar
cossytonyt
b&m quickshifts are not bad the newer ones are best
Old Mar 4, 2011 | 04:44 PM
JonnyBravo's Avatar
JonnyBravo
I run one on T5 dogbox and its very nice to use, I have heard before that you need to be careful running one on a syncro box as the faster changes are likely to wear the syncros faster, no idea if there is any truth in that but it does make sense.
Old Mar 4, 2011 | 05:03 PM
D16PJM's Avatar
D16PJM
i had one and my only complaint was it vibrated a bit but had all uprated mounts.
Old Mar 4, 2011 | 05:08 PM
carcollector's Avatar
carcollector
i dont use the bw one, i used to import the ones from 5.0 in the states, these are really really solid and make nice short shifts.
donno who imports them today but guess wot, i still got 2 new ones
before u ask, i am on holidays till end of month, no pics and prices....lol
Old Mar 4, 2011 | 05:19 PM
cossytonyt's Avatar
cossytonyt
ive got a 5.0 but its for a tremec
Old Mar 4, 2011 | 06:09 PM
JonnyBravo's Avatar
JonnyBravo
I think their called a pro shifter or something and I've also heard they are excellent !
Old Mar 4, 2011 | 06:52 PM
carcollector
the fixing plate differs. tremec is square afaik, t5 isnt.
i got a square spare, in case.
Old Mar 4, 2011 | 08:49 PM
2wd's Avatar
2wd
SO the 5,0 wont fit the T5 .. ok .. but if I would have a Q shift kit for the T5 .. witch one would you recommend to use ???
jessie_rs
62
Aug 6, 2019 09:27 PM
Billy_RS
Sep 13, 2015 04:17 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
