cracked rocker cover
Old Mar 3, 2011 | 12:29 AM
welsh.Z.S.'s Avatar
welsh.Z.S.
Default cracked rocker cover
HI ive just found a tiny crack on the top of my rocker cover on my puma engine. Does any 1 know if its a new rocker cover needed or is there a sealant that will work ? The crack is around 2mm and barely loses any oil. Thanks
Old Mar 3, 2011 | 12:36 AM
botters's Avatar
botters
competant bodger
you could get it welded
Old Mar 3, 2011 | 01:10 AM
welsh.Z.S.'s Avatar
welsh.Z.S.
Do u think any of those metal putties would be ok ? They claim to be as strong as a weld
Old Mar 3, 2011 | 08:07 AM
JonathanJ's Avatar
JonathanJ
the trouble with the putties is that if you do it on the outside it always looks s**t , and you do not want to put it on the inside in case it falls off and gets into places that you dont want it .
Your choices are a replacement , or get it welded , remember you should drill either end of the crack to prevent it continuing then get someone to run a weld along it , then you can clean it up and it will look the bis
Old Mar 3, 2011 | 01:08 PM
martysmartie's Avatar
martysmartie
The cam cover is plastic so you can't weld it, the phase 1 engines had a metal cover but I think underneath it's still plastic.
I personally would get another cam cover as that is likely to split further in the end which would cause problems!
Martin
Old Mar 3, 2011 | 05:08 PM
Plastic cam covers can be welded perfectly, see a bodyshop, quite pricey though, most likely cheaper s/h.
Old Mar 3, 2011 | 05:17 PM
welsh.Z.S.'s Avatar
welsh.Z.S.
Nope the cover is all metal guyr
Old Mar 3, 2011 | 06:00 PM
martysmartie
Oh fair enough ignore me then haha.
Martin
Old Mar 4, 2011 | 07:18 PM
Churtz's Avatar
Churtz
i believe the cam cover is a composite of magnesium/alloy on the 1.7 pumas.... i would check if it can definately be welded.
matt
Old Mar 4, 2011 | 07:48 PM
Steve_RS's Avatar
Steve_RS
For the sake of £10 - get another cam cover from a scrappy.... lol
Mark RS
Mar 5, 2021 06:08 PM
muzzman1
Sep 30, 2015 08:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
deathrider666
Sep 28, 2015 06:12 PM
