Cosworth cam question
Old Mar 1, 2011 | 10:54 AM
Trist's Avatar
Trist
Default Cosworth cam question
Are BD16 inlet and exhaust cams same profile?
The father in law has a Sapph running 430bhp but it's down on torque due to running 2 BD16s
He has another engine that is going in his other Sapph that is 360bhp. If he takes the BD16 exhaust cam out of the 430 engine and put that in the inlet of the 360 engine and put the standard inlet into the exhaust side of the 430?
So he would have 2 engines with BD16 inlets and standard exhaust.
Sorry if this is a really stupid question.
Old Mar 1, 2011 | 11:48 AM
Turbosimpsons's Avatar
Turbosimpsons
i think you can put the inlet in the exhaust but not the other way round.
Old Mar 1, 2011 | 12:11 PM
joffy's Avatar
joffy
SLOW LEARNER
i thought they both fitted but had to be timed up 180 degrees out, so the arrow on the cam pulley would point away rather than into the middle if that makes sense?
Old Mar 1, 2011 | 01:40 PM
Turbosimpsons
iirc there is a oil groove on the inlet cam, but not on the exh.
Old Mar 1, 2011 | 04:50 PM
There is indeed a scroll(groove) on the inlet cam, unless really metal power a std exhaust works fine for most.
Old Mar 1, 2011 | 10:02 PM
Trist's Avatar
Trist
he wants to change his spec that is BD16 inlet BD16 exhaust
to BD16 inlet STD exhaust
just thought it would be a cheap option as he had it all there?
Old Mar 2, 2011 | 08:30 AM
Turbosimpsons
should easily be able to pick a standard exhaust cam up. sell the 16 exhaust on after.
JoeyBoyden
Jan 4, 2024 02:36 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
