St220 aux socket
Old Feb 27, 2011 | 04:24 PM
barkman's Avatar
barkman
Newbie!
Default St220 aux socket
My mondeo st220 facelift has the Sony stereo but no aux socket in glove box. Can you connect an aux lead direct to stereo or is there a lead that I can buy to attach one?
Thanks
Old Feb 27, 2011 | 04:33 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is a slot in the back of the head unit in the square block of the main loom where you can simply plug in the aux socket
Old Feb 27, 2011 | 04:41 PM
barkman's Avatar
barkman
Newbie!
Nice one! will get out stereo and have a look. Was gutted there was no socket in glove box. Took out the glove box to check it hadn't fallen out but it wasn't there so this is excellent news!
Old Feb 27, 2011 | 06:27 PM
dojj's Avatar
dojj
all you need to do is find the same socket in another car and you can simply remove it from there and add it to your loom
just finding it is the potential problem
www.talkford.com and ask there in their wanted section if you have difficultly finding it
Old Feb 27, 2011 | 07:09 PM
barkman's Avatar
barkman
Newbie!
Thanks but now I'm confused! Is it not just a 3.5 aux lead that connects on the loom that you mention?
I'm not bothered about having an actual socket just wanna plug the iPod into the stereo. Soz if I've missed the point!
Old Feb 27, 2011 | 07:19 PM
Danster76's Avatar
Danster76
On the back of your unit there will be a block connector port. Your unit is aux compatible NOT ready. You can buy the hardware on eBay for about Ł16 all in. You'll need the block plug to 3.5mm female socket (about a tenner) and a simple 3.5mm to 3.5mm male patch lead (a couple of quid). You'll need to route the block plug to socket to where ever you want it. I looked earlier on eBay.
Most kits, and I have bought a few for newer shape fiesta applications, are stated as for use with the cd6000 stereo. I'm not familiar with the Sony plugs so unsure if they are the same or not. That's as far as I can help you.
Old Feb 27, 2011 | 08:56 PM
barkman's Avatar
barkman
Newbie!
Thanks for reply. I can't seem to find anywhere that you can buy the lead to plug into the Sony stereo. eBay has some leads but not compatible with the Sony stereo. Any idea where I can get the lead needed? I've been trawling the net with no joy for hours
Old Feb 27, 2011 | 09:19 PM
dojj's Avatar
dojj
I've got a loom somewhere withthe connector block in it somewhere and all it is is a small plug that slots inot the radio connector and ends up in an iPod type input
Old Feb 27, 2011 | 09:39 PM
barkman's Avatar
barkman
Newbie!
Any idea where to buy them!
Old Feb 27, 2011 | 10:04 PM
Danster76's Avatar
Danster76
If you can, pull your radio out and get a picture of the connection sockets on the back, I'll then compare it to the ford 6000cd unit connections and if it's the same I would buy the eBay kit and take a chance. The plug I'm on about just has 2 wires.
Old Feb 27, 2011 | 11:21 PM
barkman's Avatar
barkman
Newbie!
Thanks chaps. I'll get a pic on in the week. Really appreciate the help. Btw I know its been asked a thousand times but I can't find a definate answer, 2004 facelift, will a double din fit straight in with fitting kit to finish off with no cutting of panels etc required?
Thanks again
Old Feb 27, 2011 | 11:27 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Took our lass's Sony out a little while ago of the focus and its the same
Old Feb 28, 2011 | 06:36 AM
dojj's Avatar
dojj
Facelift with the cleaner dash and square edged radio will take a double din head unit, but I've found that certain kits sit too far forward and don't slot in all the way home.
Old Feb 28, 2011 | 09:45 AM
barkman's Avatar
barkman
Newbie!
Thanks guys. Will consider that as an alternative if I can't get this lack of aux socket sorted. Can't believe that nowhere (that I can find) on her majesty's web is there direct reference to this lead/loom that is needed. Loads on the older players but not the Sony one
Old Feb 28, 2011 | 10:20 AM
barkman's Avatar
barkman
Newbie!
Update. Found this
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_5273wt_810
When I removed glove box there is a lead behind with a similar looking connected that isn't plugged into anything. Is this anything to do with the aux so this lead might fit?
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Iain Mac
Sep 13, 2015 09:16 PM
Si B
Sep 12, 2015 06:49 AM
