Focus 1.6 engine
Old Feb 26, 2011 | 04:37 PM
SWIFTY's Avatar
SWIFTY
Default Focus 1.6 engine
Does the 1.6 zetec se fit in the s
What are the differences??
Thanks
Old Feb 26, 2011 | 04:46 PM
martysmartie's Avatar
martysmartie
The first generation known as phase 1 had a metal cam cover scribed with Zetec-S, the later phase 2 engine had a plastic cam cover with Zetec-SE printed on it. They are both the same engine to all intents and purposes and are interchangable it's just the phase two has some internal differences like valves etc.
The same engine can be found in the Fiesta Zetec S.
Martin
Old Feb 26, 2011 | 06:06 PM
SWIFTY's Avatar
SWIFTY
Thanks
That's good because I can find plenty of se engines I'n the scrap yard.
Any ideas if it's easier to take the engine out with the box or leave it I'n the car an just split it.
Thanks
Old Feb 26, 2011 | 08:23 PM
martysmartie
Yes it's the same engine mate just different names on the cam cover, plenty refer to the engine as the Zetec-S for both guises.
Woulden't know about the removal, although I should think leaving the box in situ would be easier as then you just have the engine to worry about.
Martin
Old Feb 26, 2011 | 08:38 PM
SWIFTY's Avatar
SWIFTY
Thumbs up
Thanks again.
Old Feb 26, 2011 | 09:19 PM
Bailes1992's Avatar
Bailes1992
The SE i'm sure is a little bit stronger in the bottom end side of things. The silver tops tend to have bottom end issues.
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
