Fuel pump relay controlled by ECU? which one?
Old Feb 25, 2011 | 10:28 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default Fuel pump relay controlled by ECU? which one?
Got a non running turbo cab the other week, and first things first the fuel pump aint priming. The relay is ok and i'm fairly sure the pump is too, the previous owner has tried various ecu's etc - so my question is, do either of the black or silver ECU's control the fuel pump circuit?
Old Feb 25, 2011 | 07:21 PM
DazC's Avatar
DazC
No. Unless it's a Series 1 turbo.
If it has a pink relay, it is triggered by the negative side of the ignition coil on a green wire.
Old Feb 27, 2011 | 06:54 PM
Zetec_mk4_XR3i
thanks mate
mint_s2
Sep 2, 2015 08:58 AM
jonjg
Sep 1, 2015 03:46 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
