Coolant Route YB..........
Old Feb 24, 2011 | 08:38 PM
Hoogi's Avatar
Hoogi
Default Coolant Route YB..........
Just need some clarification on where the Coolant travels around a YB Engine ?
I have a RS500 Engine (YBD Small Core) - it has the 4WD Thermostat housing......
The bits I'm interested in is the outlet from the Water Pump - thinks it's just the one outlet at 7-8 o'clock ? Where's that supposed to go ????
And the two outlets from the Thermostat housing........
I would like to feed my Turbo with one, the smaller one at the top back that points towards 9 o'clock. Would this be OK ?
The larger outlet faces forward from a 90degree elbow and I'd like to send this round to the Inlet at the back right hand corner of the Block. Again, would this be OK ?
Many thanks..........
Old Feb 24, 2011 | 10:23 PM
rscos2004's Avatar
rscos2004
Hi the hose on the left as youre looking under the bonnet goes to youre radiator one off the waterpump if you have fitted a 4x4 pump joins with a small modine pipe to housing one small outlet goes to header tank the best thing for water from turbo would be fit a turbo cooler.
Old Feb 25, 2011 | 08:50 AM
Hoogi's Avatar
Hoogi
I have 3 Ports on my Header Tank..........
1) Swirl Pot back to Header Tank Size -6
2) Turbo Cooler back to Header Tank Size -6
3) Header Tank to Radiator Bottom Hose Size -10
So, guessing I can "Blank Off" the outlet from the Water Pump ?
Does that sound right ?
Old Feb 25, 2011 | 12:20 PM
rscos2004's Avatar
rscos2004
I wouldnt blank any off if you dont have a 4x4 waterpump fit one if local you could have a look at mine.
Old Feb 25, 2011 | 02:24 PM
Hoogi's Avatar
Hoogi
Yep, I have a 4x4 Water Pump........so where is that oulet supposed to feed ?
Unfortunately I'm not that local
Many thanks......
Old Feb 25, 2011 | 03:54 PM
rscos2004's Avatar
rscos2004
Many thanks......
Hi click on my pic of my engine gives a brief pic of waterpump and swirlpot fitted.
Old Mar 2, 2011 | 07:55 PM
Hoogi's Avatar
Hoogi
Where do I need to go for the Engine pic ?
I'm still stuggling to get to grips with this one
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
