More Mk1 focus problems!
Old Feb 24, 2011 | 11:25 AM
Garfiun's Avatar
Garfiun
Default More Mk1 focus problems!
Ive got a 98 1.6 focus and there is a problem with the revs.
It idles fine and revs up fine but when you back off the pedal and the revs come below 2000 the engine stutters and drops down to about 300 and sometimes stalls or picks the revs back up.
It also does this while slowing down too.
Any help appreciated.
Old Feb 24, 2011 | 03:10 PM
focii dan nick's Avatar
focii dan nick
99 focus zetec
sounds like your speed sensor has gone faulty its located ont the gearbox, or possibly your air idle control valve on the throttle body
Old Feb 24, 2011 | 05:25 PM
Garfiun's Avatar
Garfiun
Ive cleaned out the aicv and it is running better but the problem is still there and what should i look for on the speed sensor.
Old Feb 24, 2011 | 06:00 PM
focii dan nick
99 focus zetec
theres nothing really to look for its just a replace jobby. this cured my 1.8 having the same problems, rough running, not idleing ect. but be carefull if you do replaceit can be a bugger if you break the pin like i did, half hour job turned into a day job lol
Old Feb 24, 2011 | 06:14 PM
offitmassive's Avatar
offitmassive
throttle position sensor
Old Feb 24, 2011 | 08:25 PM
Garfiun's Avatar
Garfiun
Are these right -
http://cgi.ebay.co.uk/NEW-FORD-MONDE...item45f839cb0d
http://cgi.ebay.co.uk/NEW-GENUINE-FO...item3caa6d1486
Old Feb 24, 2011 | 09:20 PM
RichieST's Avatar
RichieST
I'd replace the idle control valve first, the most easiest to do and the one most likely to be giving you the issues! Cleaning it isn't always the answer as they are so sensitive.
Old Feb 24, 2011 | 09:40 PM
Garfiun's Avatar
Garfiun
I did notice a bit of an improvement after cleaning it up ill change that first.
Thanks.
Old Feb 24, 2011 | 09:43 PM
focii dan nick
99 focus zetec
they look like the ones just make sure its the corrct one for ur car saves hastle later. and yea defo change AICV first the speed sensor is a nightmare
Old Feb 25, 2011 | 12:55 PM
martysmartie's Avatar
martysmartie
I personally don't think it's the VSS due to the fact you say it idles fine! From that description it sounds more like an air leak to me, have you checked the vaccum hoses as it's a very common problem with them cracking thus introducing an air leak!
Easiest way to check VSS before simply just replacing it is to coast in neutral AND release the clutch at around 10MPH the revs should rise to around 1400RPM thus showing the VSS to be working, also this would effect your speedo I would have thought.
Martin
Old Feb 25, 2011 | 02:16 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I'd be thinking a vaccum leak or perished / collapsed hose. Check the PCV (positve crankshaft vent) hose under the manifold. There is one end attached to a valve that can get full of gunge. It's a cheap replacement from ford, but a bit fiddly to change. Use a long pliers to remove it.
Old Feb 25, 2011 | 03:59 PM
Garfiun's Avatar
Garfiun
Thanks for that what other hoses could I look at?
And id does seem like its sucking in too much air.
Old Feb 25, 2011 | 04:33 PM
martysmartie
LOL thats exactly what I said above? "From that description it sounds like an air leak to me, have you checked the vaccum hoses as it's a very common problem with them cracking thus causing an air leak?"
As I say the vaccum ones are the usual suspects so check these first.
Martin
Old Feb 25, 2011 | 05:45 PM
Garfiun's Avatar
Garfiun
Where is the vacuum hose located?
Also how should the ht leads be set out?
They where all taken off when the coil pack was changed but I don't think they were put on properly.
Old Feb 26, 2011 | 09:38 AM
martysmartie
The hoses run across the front of the engine etc, the PCV one can collapse with age but there are others.
The HT leads have to be connected in relation to firing order, I.E 1,3,4,2, if put back on wrong the car would misfire.
Martin
Old Feb 26, 2011 | 02:26 PM
Garfiun's Avatar
Garfiun
Martin
I cant find the pcv hose and how is the firing order matched up to the coil here is how mine is -
Old Feb 26, 2011 | 03:15 PM
RichieST's Avatar
RichieST
That's wrong, cylinder 1 is on the left, and it goes 1, 2, 3, 4. There should be a sticker on top of the coil pack saying what goes to what plug.
Old Feb 26, 2011 | 04:42 PM
martysmartie
The PCV is located on the front of the enginne low down.
Martin
Old Mar 3, 2011 | 09:25 PM
Garfiun's Avatar
Garfiun
Ive been looking for the pcv but cant find it and ill look at the coil pack tommorow.
The car is going in to see whats wrong tuesday if I dont sort it by then.
Thanks everyone.
Old Mar 3, 2011 | 09:30 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
It's under the manifold, the 4 pipes on the engine. It's a rubber pipe with 3 outlets on it.
Old Mar 4, 2011 | 10:00 PM
Garfiun's Avatar
Garfiun
Ill give it another look tomorrow didn't really get a chance today.
Old Mar 8, 2011 | 07:04 PM
mercgrey's Avatar
mercgrey
i cured mine with swaping the pipes mate it runs from behine the inlet and runs round the engine conecting to the pcv, it has a join just under the thermostat housing iirc! mine had a split around 3inch long
Old Mar 14, 2011 | 10:04 PM
Garfiun's Avatar
Garfiun
Well the aicv is working, at least when you run live to it it clicks open and I got fed up of it so its up the garage this week now.
Old Aug 8, 2011 | 03:59 PM
morganj's Avatar
morganj
Did you ever get this sorted? My 2002 1.6 (Zetec SE) has this problem sometimes. I've tried a new idle control valve and PCV. No splits apparent in vac hoses. The Ford garage diagnostic showed no fault and after more than an hours labour cost they found no reason why it should happen.
I had the cam belts replaced not long after I bought the car and the fault has been only since then - but I cannot imagine their is a connection.
Replacing the speed sensor?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
