Sierra steering rack
Hi guys
Will a standard non power sierra rack fit in a sierra cosworth as I am going electric power steering and will maybe use the sierra rack with the quaiffe quick rack and pinion conversion?
Cheers Dave
Cheers Dave
thanks mark
not sure if you will need to find the non power assisted intermidiate shaft to fit this
there were a few different versions available and some had one uj in them and some had 2
I run it on my 3 door rally car, one of the best things I have ever done!!
I use a std rack with the quaife kit in.
Hi, you will need the non powered steering coupling as its longer than a std one. If you can replace the lower "rubber" jiont with a poly one or another u/j.
I have seen racks and quick kits available, but not found the steering joint coupling anywhere
What spline is on a cossie rack?. save me counting it LOL
chowfornow
14
Jan 5, 2019 09:01 PM
Adam Graham
Sep 6, 2015 06:04 AM
