Saph Cossi Engine bay loom
Old Feb 17, 2011 | 12:36 PM
robbo9006's Avatar
robbo9006
Default Saph Cossi Engine bay loom
My car is coming on nicely .
I put the ecu in and the engine bay wiring loom.
The connecter were the engine bay loom joins the main loom is missing.
1 st question is behind the ecu up inside the dash is a loom that goes across the top with a connector.
Is this the connector the engine bay loom joins.
Any advice or pics on this area of the car would be helpful.
Also any advice or pics on the ecu proper bracket locations.
not the main ecu as that one was easy.
My mechanic has just thrown em behind the glove box.
I at some point will have to open the can of worms and find proper homes for the ecu's ect
Old Feb 17, 2011 | 07:31 PM
If 4wd, they live behind the glovebox rear area.
The main connector the ecu plugs into is normally tucked behind the massive loom that runs across the base of the screen area inside the car, it will have 6 wires coloured,
Thin green = tacho
Red/blue = Permanent live
Black = switched live(ignition)
Black/red = fuel pump live output
Brown/white = temp sender for GAUGE
Brown/red = air con
Old Feb 17, 2011 | 07:49 PM
robbo9006's Avatar
robbo9006
Its a 2wd but this is good info .
Thankyou
Old Feb 17, 2011 | 08:37 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Thin green = tacho
Brown/red = air con
The loom connection is behind the battery on 4x4's.
Old Aug 28, 2011 | 12:51 AM
robbo9006's Avatar
robbo9006
The black wire seems to come through the fire wall into the engine bay and then just stops .
If it is the switched live(ignition)
should this then be connected to the red live of the battery.
Old Aug 28, 2011 | 09:31 AM
robbo9006's Avatar
robbo9006
Bump
Is the black thickish wire,connected to the battery
Old Aug 28, 2011 | 10:30 AM
Puss2's Avatar
Puss2
Formerly know as Puss
I have the dash out of mine at the mo Wat pics do u need mate?
Old Aug 28, 2011 | 01:53 PM
robbo9006's Avatar
robbo9006
Ive done the black wire.
I seen the same type of wire bolted onto the positive red side of the battery.
I reconnected it.
I think it is the ignition positive.
I am looking at the breather system and starter moter small wire.
What is the colour of the starter moter wire.
Is it like a orange and blue and comes of the n/s chassis rail area near the front earthing point.
I would like a pic of were the small starter moter wire comes from.
I think its were the green coil wire comes from.
Any pictures of the breather system or a diagram would be good.
Or even a discription would help.
Old Nov 15, 2011 | 06:09 PM
robbo9006's Avatar
robbo9006
wich is the wire for the starter moter then.
Is it this one as mine is missing somewere and i am going to create a new starter moter remote.
Old Feb 4, 2012 | 09:16 PM
charliecossie's Avatar
charliecossie
Are these wire colours the same for 2wd aswell?
Old Feb 11, 2012 | 05:26 AM
robbo9006's Avatar
robbo9006
Well mine is the 2 wd.
The main player was the black wire behind the dash.
It connected to the coil.
Old Feb 17, 2012 | 07:05 PM
robbo9006's Avatar
robbo9006
This car is working now and all is well.
The black wire under the dash connected to the coil and all runs good.
Thankyou
j.hammond1
30
Oct 31, 2021 05:28 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
track.focus'd
Aug 12, 2015 05:53 PM
yawiejon
15
Aug 9, 2015 06:36 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
