plug n play ecu
Old Feb 2, 2011 | 09:26 PM
YBT200's Avatar
YBT200
Default plug n play ecu
hi, is there someone who is using a plug n play ecu for an esort cosworth which works well with the std sensors, or using a plug n play adapter to any after market ecus? what are you using?
Old Feb 6, 2011 | 08:22 AM
Lars_Ferm's Avatar
Lars_Ferm
I run autronic sm4 and havent cut a wire in the loom.
Old Feb 7, 2011 | 09:19 AM
YBT200's Avatar
YBT200
so than do you have a patch loom from the autronic to the std ecu weber soket?
Old Feb 7, 2011 | 09:21 AM
YBT200's Avatar
YBT200
what about gems ecu they do 1 direct replacement which uses all factroy sensors and same p8 socket? anyone used one of them?
Old Feb 7, 2011 | 03:59 PM
Lars_Ferm's Avatar
Lars_Ferm
I used a abs box and took the socket and made a adapter to my weber socket.
Old Feb 7, 2011 | 07:48 PM
foreigneRS's Avatar
foreigneRS
Testing the future
get your P8 converted by RPLabs so that you can map it and add features like ALS, launch control etc to an OE quality product
Old Feb 7, 2011 | 07:55 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
or buy a good after market one that has got all them features plus more already in it and will be as good quality wise as the oe one
Old Feb 7, 2011 | 09:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i doubt it. not saying it will be bad quality, although some aftermarket ones are, but hardly any of them are up to OE standards.
Old Feb 7, 2011 | 09:13 PM
ajamesc's Avatar
ajamesc
whys that then modern ecu technology is much more advanced and at a guess so are the materials used building process and computing power they have my autronic ecu has been in the car for 5 years now never given me a problem
DixieTheKid
11
Jun 6, 2020 11:20 AM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
DixieTheKid
Sep 14, 2015 09:04 PM
ST-170
Sep 4, 2015 11:02 AM
