FREE FILTHY PORN.....
Old Feb 2, 2005 | 08:52 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default FREE FILTHY PORN.....
scroll down
now i have you attension.....
will a 2WD cos fuel pump fit in m6 escort tank??
please
anyone???????????????????????????????????????????? ???
Old Feb 2, 2005 | 08:57 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
No. 2wd pump is a gravity fed pump that lives outside the tank . You could feed that standard lift pump straight into the gravity one though, which would be okay for around 300bhp .
Old Feb 2, 2005 | 09:14 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
right o... cheers mike
and how the fook is that achived??
also, how will it give more pressure?
is it case of a bit of fuel hose from existing pump to 2wd one, then 2wd one to normal fuel line?
what about the fuel return??
you got any diagrams at all mate??
Old Feb 2, 2005 | 10:02 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Feb 2, 2005 | 10:07 AM
Mike Rainbird
Caraholic
The fuel return would be as is, you're just adding the gravity pump into the system, that gives it the required flow you are after. Nothing else changes.
I had this set up on my Escort running 400bhp (lift pump feed direct into 044 gravity pump). I only changed the lift pump to feed in to a swirl pot before hand, when I fitted the eight 803s...
Old Feb 2, 2005 | 10:09 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
ok mike, so what you are saying is basically stick the 2wd one inline with whats on the car at the mo??
and thats it?
cheers btw lol
Old Feb 2, 2005 | 10:10 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
oh ah, and how would the second pump be powered?
just splice off from the in tank loom connector??
Old Feb 2, 2005 | 10:17 AM
Mike Rainbird
Caraholic
Dan,
Yep that's it.
It would be best to give it a seperate power supply with it's own relay etc...
R4N SS's Avatar
R4N SS
cooont
Old Feb 2, 2005 | 10:20 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
soz ran lol.
mike, would i still go via the fuse box for the existing pump?? have an inline fuse and what else would the relay go to? switched ignition?
cant think at the mo....
Old Feb 2, 2005 | 10:24 AM
Mike Rainbird
Caraholic
The Escort Cossie has seperate relays for the fuel pump that are not in the fuse box, so it is easy. However, just use your common sense and make sure it is correctly fused and wired up to an ignition live as the OE item.
Old Feb 2, 2005 | 10:25 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
thanks for your time mike
cheers
Old Feb 2, 2005 | 10:29 AM
darren.cudd's Avatar
darren.cudd
mike you feeling ok? you just did a whole 3 replies without using the . icon
Old Feb 2, 2005 | 10:31 AM
Mike Rainbird
Caraholic
I don't usually use the when providing technical info, so .
I only use the , when taking the piss / bantering with eejits , so
Old Feb 2, 2005 | 10:38 AM
darren.cudd
thats better
oh and mike.....
Old Feb 2, 2005 | 10:41 AM
mattbibs's Avatar
mattbibs
now where is the filthy porn??
Old Feb 2, 2005 | 10:44 AM
JAP CRAP's Avatar
JAP CRAP
you have NEVER posted a reply to me without the ... :
Old Feb 2, 2005 | 10:46 AM
darren.cudd
lets not forget mikes personal favourate
Old Feb 2, 2005 | 10:54 AM
JAP CRAP's Avatar
JAP CRAP
Old Feb 2, 2005 | 10:56 AM
darren.cudd
i think that calls for a.....
Old Feb 2, 2005 | 11:02 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
oh dear
Old Feb 2, 2005 | 02:15 PM
Mike Rainbird
Caraholic
That's because you're the BIGGEST eejit out there . I don't know anyone as indecisive as you, and that includes all my female friends .
You can't even decide what to do about a set of fucking hoses .
tankybaby66
Feb 6, 2016 02:24 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
muzzman1
Sep 30, 2015 08:59 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
