Tapping 2wd cossie sump
Old Jan 29, 2011 | 03:59 PM
mattman1234's Avatar
mattman1234
Default Tapping 2wd cossie sump
Has anyone tapped a thread into the side of the sump without any probs,seems there is enough meet on there to save a boss being welded in.I want to put a 5/8 union into the side for my oil drain return
Old Jan 29, 2011 | 04:41 PM
nicksaph's Avatar
nicksaph
is the sump ally?
i have tapped and threded the sump on my 4x4 to fit a oil temp gauge sended with no problems at all.
cheeRS nick
Old Jan 29, 2011 | 04:46 PM
mattman1234
yep,its ally
Old Jan 29, 2011 | 08:45 PM
Not really thick enough, imo to do this reliably and safely, it's only around 4mm thick, can you not use the sump plug and put a adaptor in there for return ?
Old Jan 29, 2011 | 09:38 PM
mattman1234
Yep that could my other option,just a pain when i want to change oil
Old Jan 30, 2011 | 05:36 PM
Having to undo a jubilee clip holding on a pipe to the sump plug is less hassle than a tapping in the sump failing though!!
Old Jan 30, 2011 | 08:40 PM
AndyPen's Avatar
AndyPen
If the sump is off you can use a plumbing fitting like the group A cars did.
Old Jan 30, 2011 | 08:57 PM
2wd's Avatar
2wd
plumbing fitting ? ... please explain.
Old Jan 31, 2011 | 02:52 AM
mattman1234
is that tapped in,or is there a nut on the other side ?,do you know what size thread was used
Old Jan 31, 2011 | 08:52 PM
bad boy rs's Avatar
bad boy rs
heres mine welded on
Old Jan 31, 2011 | 09:37 PM
AndyPen's Avatar
AndyPen
Mine has a nut on the inside - spotted the very same fittings in a hydraulic factors for a few quid. Dowty seals are there too... the rubber and metal ones.
Old Feb 1, 2011 | 02:48 AM
mattman1234
Think the nut on the inside is the way forward
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
