a little help please lads
hello chaps,a little help needed,got my self a new 2wd thermostat housing for my 2wd sapphy and when i got it i thought champion,went out side to have a look at the old 1 and i noticed it has 1 inlet pipe on the side but the 1 i got off burton has 2 as seen in the picture
http://cgi.ebay.co.uk/New-Cosworth-YB-Thermostat-Housing-Sierra-2wd-/150550466260
have i ordered the wrong 1 with it having 2 inlet pipes or is it ok to use.
thankyou lads
thankyou lads
Yes does seem strange that is the the feed for the heater or turbo can't remember which perhaps they have made it so you connect both feeds to the housing hence two unions, it defo says it's for the car.
Martin
Martin
you could use a piece of silicone hose with a bolt in it secured with a hose clip,
or alternativly(sp) ford did a blanking cap for the pinto and would assume that the cosworth had the same cap, might be worth trying your local dealer!
cheeRS nick
cheeRS nick
Minirotty
11
Sep 15, 2015 10:16 PM
