Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
no side lights fiesta 1.3 encore
Old Jan 23, 2011 | 11:49 AM
davidpdavies's Avatar
davidpdavies
Default no side lights fiesta 1.3 encore
Hello all, I am having a problem with my N reg fiesta regarding the lights. No Front or Rear side lights and no dash lights. Full beam and flasher works as well as indicators,wipers and washers. Suggestions please
Old Jan 23, 2011 | 03:50 PM
Start at the fusebox, checking all fuses, if the festa has a normal side/head smaller stalk on the right it could be this that is duff, could just be a broken feed to it, or after it to the dip/main stalk, or if the "ring" sort of side/head around the base of the indicator it's very likely to be this.
The power for the flash(main) is independant so they work even with lights off, this however won't power the normal push forward for main beam, but this talk when pulled rearwards will work the main beam on the spring setting.
The indicators, wipers, washers are yet another seperate supply.
One of this annoying things that is dead easy to fix if there, what you are missing is the feed to or from the side/head selector switch.
Old Jan 23, 2011 | 03:57 PM
RichieST's Avatar
RichieST
Does your dipped beam work?
Old Jan 24, 2011 | 09:26 AM
davidpdavies
Yes richie, dipped beam works but just noticed that as well as the side lights,rear lights,dash lights the number plate light is not working.
Old Jan 24, 2011 | 09:32 AM
P 17eed's Avatar
P 17eed
I have had this a few times on fiestas and escorts, the main light/indicator switch is faulty. If I remember right the lights on warning wont work either.
Old Jan 24, 2011 | 09:35 AM
davidpdavies
P17 yeah no alarm noise when door is open,
Old Jan 24, 2011 | 09:54 AM
P 17eed's Avatar
P 17eed
Yes I would go for the main switch then. Motor factors do them or scrap yard. If I remember right from ford they are about £100.
Old Jan 24, 2011 | 09:59 AM
davidpdavies
off to the local breakers it is then folks, will keep you posted on the outcome
Old Jan 24, 2011 | 12:18 PM
davidpdavies
updated : got a replacement light stalk from the breakers and fitted it. the unit buzzed and now the wipers are stuck and wont move back .............
Old Feb 1, 2011 | 04:31 PM
davidpdavies
final update : Managed to figure out the wiper fault, there is another fuse box hidden away behind a plastic coin tray and there was a blown fuse that needed replacing. As for the light problem this was sorted by purchasing another light stalk from a decent breakers in the area.Thanks for the advice people
Old Feb 1, 2011 | 04:35 PM
davidpdavies
Fords wanted £132.00 for a new part but found a company called "Parts-4-fords on ebay and they have them for £39.99 (New) if anyone has the same problem in future
Old Feb 1, 2011 | 04:36 PM
RichieST's Avatar
RichieST
Sounds like a fault with the first stalk you bought, glad its sorted!
Old Feb 1, 2011 | 04:42 PM
davidpdavies
yeah the first one i bought was from RKR Malmoco in Worcester and they sold me one from an escort, they were not interested in why it didnt work, more interested in the money they were making. lesson learnt
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
Bobby9779
Aug 11, 2015 06:47 PM
Bosch
Aug 4, 2015 05:14 PM
turbobill
Aug 1, 2015 08:55 PM
