General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
people may differ, but was wondering if people just use neat coolant or dialute it with water? i alway suse neat but wondering wether this is a bad idea?
if it says you can use it neat then its up to you, im too tight personally, the stuffs fooking expensive if you want to completly fill a system with it!
Neat coolant in the case of Ethylene Glycol can eat away water passages, and anything else made of copper or aluminum, really nicely, even though it may(should) have biocede in it, it will eat the material.
Another thing to consider is that it is way less effecient as a coolant than say a 50/50 mix, as the water is used as a catalyst to help increase heat absorbtion into the medium/coolant.
like tab said neat will corrode the block,head, rad over time
poss head gasket failure as well
50/50 mix is ok
also no anti freeze it will do the same
