Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
1.8 xflow
Old Jan 19, 2011 | 11:34 AM
spud-rs2k123's Avatar
spud-rs2k123
Default 1.8 xflow
As above did they make one as standard. It's just my dad is looking in to buying a kit car which the guy is saying it cones with a 1.8 xflow standard. Which we both find strange as you only see 1.6 xflows any info would be great
Old Jan 25, 2011 | 07:45 AM
There is a version of the later x flow based on the 711M, called the AX made in south africa, it is basically a thicker walled block, that can be taken out easily to 1825cc, with oversize pistons, with stroking around 2000cc is available using a modified datsun crank.
On true x flow 711 blocks 1760cc(pistons only) was regarded as a safe limit, this may be what the advertiser means ?
Old Jan 26, 2011 | 06:10 PM
16 sport's Avatar
16 sport
Agree with tabetha the only x-flows i have come across are 16 bored out to 1740-1760 at a push but this is towards the xtreme end of the engine especially for drivability........this is more suited to track days than town driving.
Old Jan 26, 2011 | 06:32 PM
fridgeman's Avatar
fridgeman
ask him just that, why is it a 1800cc when they never made one,chances are they mean a pinto out of a old sierra. if insists its a x flow ask him for a spec list and post it up,we,ll have a look.
Old Jan 27, 2011 | 05:17 PM
graham c's Avatar
graham c
could be a cvh ?
Old Jan 27, 2011 | 06:42 PM
It is possible to get 1800cc on a 711m block, but bloody expensive, not personally seen it done, but know it has been done, by stroking as well as boring.
Old Jan 31, 2011 | 05:45 PM
spud-rs2k123
hi folks thanks for the replys ive since brought the car and with abit of info ive found out here and there i brought it as a 1600 not an 1800 so when i do take it apart if its anything else its a bouns
thanks
Old Mar 29, 2011 | 06:20 PM
TimGR's Avatar
TimGR
thanks
What's the letter after the engine number 711?
I had an 1840cc crossflow. But as above, generally only up to (under) 1800cc is possible on the 711 block.
Daniel Howard
Oct 3, 2015 10:44 PM
liamT74
Sep 23, 2015 10:24 PM
pie-face
Sep 15, 2015 10:43 AM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
