what lb rate for coilovers
Old Jan 18, 2011 | 04:08 PM
155lee's Avatar
155lee
Default what lb rate for coilovers
whats the best compromise for a road car that may do a few track days,im going for gaz golds and you can get any spring with them when ordering new.ta,lee
Old Jan 18, 2011 | 04:23 PM
Paul_RS's Avatar
Paul_RS
Can they not advise you?
Old Jan 18, 2011 | 04:25 PM
155lee's Avatar
155lee
yeah,i just thought id ask here 1st to see what others were using,to compare to what they advise.,im buying them from woodford garage and their advice is pretty good.
Old Jan 18, 2011 | 04:54 PM
Paul_RS's Avatar
Paul_RS
You're best going with the seller matey, or get them from rainbummer instead as he has worked out what springs work well with those shocks
Old Jan 18, 2011 | 06:14 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Im running 650lbs fronts and 400lbs rears, really good on track but bad on the road due to the crap roads we have!!
Old Jan 18, 2011 | 06:16 PM
Char1ie's Avatar
Char1ie
I run 500 front and 250 rear on my race car.
I think we had a thread the other day where we reckoned 300 front and 200 rear would be good for a road car. Of course, if you don't like it you can change in 10 mins and sell the old ones on Ebay.
Charlie
Old Jan 18, 2011 | 06:19 PM
On AVO's I run 300lb 9" front, and 200lb 12" rear, but find the rear is too soft so going to 250lb rear.
Old Jan 18, 2011 | 06:53 PM
KSA-Cossie's Avatar
KSA-Cossie
I've got 350 fronts and 180 rears.
Old Jan 18, 2011 | 08:45 PM
gibbo frst's Avatar
gibbo frst
My gas golds have 350 front which are a bit hard for my liking and had 275 on the back but changed to 225 and are much better. I'd prefer a little softer all round if I'm honest for the shitty roads where I live
Old Jan 18, 2011 | 10:02 PM
Paul_RS's Avatar
Paul_RS
I have red fronts and red rears
Old Jan 19, 2011 | 04:02 PM
155lee's Avatar
155lee
gaz have came back and recommended 400lbs front and 250lbs rear,the guy used to work for leda competition springs.does this sound ok for a road car?
Old Jan 19, 2011 | 04:12 PM
Char1ie's Avatar
Char1ie
On the stiff side but should be OK. It's so personal I think. What do you like and what is your car like now?
Charlie
Old Jan 19, 2011 | 04:21 PM
155lee's Avatar
155lee
the car was on similar rates,think the rears were 500 rear and 250 front,only drove it 5 miles and felt ok,as soon as i bought it i stripped it so didnt get used to it.
my last saph was on cheap gaz coilovers and didnt feel too bad but i hardly used that either.
Old Jan 20, 2011 | 09:33 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Mine are (off memory) 325 front and 175 rear....and IMHO the rear is too soft
Old Jan 20, 2011 | 10:16 AM
Char1ie's Avatar
Char1ie
Just go for my racecar set up: 500 front, 250 rear. At least you'll know it'll work for you at Brands
Charlie
Old Jan 20, 2011 | 02:24 PM
dazzle740's Avatar
dazzle740
Try having a chat with Martin of reyland motorsport as he seems pretty genned up on things like that, if it mainly for on the road have you considered koni/ahmed set up and a 6 degree rear beam.
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
