Removing saph turbo...??
Old Jan 17, 2011 | 08:23 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Default Removing saph turbo...??
Hello,
Well as you might know im new to engines as such and i wanted to remove my turbo...
I have took off the 3 bolts on the exhaust bit BUT the 4 bolts on the bottom on the turbo look a cunt...
Should i try my best and remove these or is it best to try and remove all 60,000 bolts on the manifold then take it all out and remove the turbo?
If it helps its a 4x4 and the engine is in the car so i cant get around properly.
Many Thanks Eigdoog.
Old Jan 17, 2011 | 08:27 PM
Mark V8's Avatar
Mark V8
It's a knuckle skinning pain of a job, I ended up grinding and bending spanners to fit. But it is possible without taking the manifold off.
Mark
Old Jan 17, 2011 | 08:30 PM
paul16v's Avatar
paul16v
Monte 087
It's a bit of a pig to do but it is possible to do without taking the manifold off personally I think its harder to get the manifold off than the turbo istelf, always manage with a 17mm stubby spanner.
Old Jan 17, 2011 | 08:34 PM
R5FORD's Avatar
R5FORD
Manifold is way easier imo.. easier to get to all the nuts and you dont have to piss around when trying to put it back together mate
Old Jan 17, 2011 | 08:49 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
So ill have to bust my knuckles what ever way i do it, Well i didnt want to take the manifold off but if it was 100% easier i would of. So ill just get a sledge hammer out and keep hitting it till it comes off, About 7 hits?
Old Jan 17, 2011 | 08:54 PM
R5FORD's Avatar
R5FORD
Try 5 hits should do it
its entirley down to you mate.. just make sure you soak the nuts/bolts in wd40 over night makes a huge diffrence.
Old Jan 17, 2011 | 08:59 PM
v man's Avatar
v man
Zee Germans are coming
and if they are a real cunt heat them right up with a plumbers heat gun
Old Jan 17, 2011 | 09:04 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
SHIT!
Was going to put WD40 on it today and do it tomorrow and forgot!! Not at home tonight either! Looks like it will be a sledge now
Cheers for the help guys!
Old Jan 17, 2011 | 09:11 PM
Char1ie's Avatar
Char1ie
You talking about the four bolts with the 12 point heads facing downwards? I jack up the car, loosen the engine mount, jack up the engine and use a long extension bar from underneath lying on the floor. Horrible fucking job.
Charlie
Old Jan 17, 2011 | 09:17 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
That really works?
Charlie
Im just gunna try from the top as i hate getting under it when i jack it up lol
Old Jan 17, 2011 | 09:27 PM
v man's Avatar
v man
Originally Posted by Eigdoog
That really works?
yeh heating metal makes it expand so the manifold will expand from the bolts
not a noticable amount to look at but works a treat
also put some wd40 on before you start
it wont take long to penetrate
and if they are really super tight try tightening them a bit more being very careful and that might help to crack them off
but yeh really heat the bolt around the manifold
Old Jan 17, 2011 | 09:55 PM
Char1ie's Avatar
Char1ie
That really works?
With axle stands obviously if you do go from underneath.
Charlie
Old Jan 17, 2011 | 09:59 PM
paul16v's Avatar
paul16v
Monte 087
Charlie
He is on about the 4wd manifold bud, the 2wd one is a piece of piss in comparison IMO.
Old Jan 17, 2011 | 10:11 PM
Char1ie's Avatar
Char1ie
Ah, OK, thanks. Ignore everything I've said
Charlie
Old Jan 17, 2011 | 10:14 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Oh so the 4wd is a fucker anyway?
Old Jan 17, 2011 | 10:16 PM
mechanic28's Avatar
mechanic28
i had my turbo on and off my sapp so many times can do it in 20 mins now lol they aint to bad to get off really,the manifold is a ok job part from 3/4 of the nuts are abit of a bitch to get too!i would defo go the getting the 4 bolts undone on the turbo
Old Jan 17, 2011 | 10:17 PM
mechanic28's Avatar
mechanic28
just to note mine is 2wd lol!
Old Jan 17, 2011 | 10:48 PM
Rax's Avatar
Rax
Glad you said this because I was wondering what all the fuss was about.Did mine piece of piss smoking fags drinking tea and chatting,oh wait a min that was after I realised I didn't need to undo the four 17mm's
Just the 6/8/12 star or whatever they are (10mm socket) all done.
I did think the only difference was the snail positioning though,slacken and spin ?.
Old Jan 18, 2011 | 07:06 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
on a 4wd manifold you simply un bolt and remove the compressor snail first
this will give you easy access to the 4 turbo retaining studs and the oil pick up pipe
but what do I know
Old Jan 18, 2011 | 07:59 AM
R5FORD's Avatar
R5FORD
but what do I know
Dosent that depend on the turbo?
Or is it the same theory for all of them?
Old Jan 18, 2011 | 04:34 PM
Eagle's Avatar
Eagle
Super Moderator
cut a spanner down to size .. 1/3 length normally works
Old Jan 18, 2011 | 06:59 PM
Fewkesy's Avatar
Fewkesy
ive recently done this on mine, but cant remember exactly how i did it but it is possible without cutting any spanners. drop the alternater and oil return from the turbo and it gives you a bit more room if i remember correctly! it just seems that you dont seem to be getting anywhere fast but you get there in the end.
Old Jan 18, 2011 | 07:12 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
So i gave it ago today, I got the two bolts off (away from the engine) easy as anything BUT i cant get the other two on the near side to the engine...
Also i have snapped a spanner in trying
Old Jan 18, 2011 | 07:29 PM
botters's Avatar
botters
competant bodger
i just take the manifold off on 4x4's i find this easier allthough a couple of the manifold bolts can be a pain to get too but a stubby 13mm spanner should see you right
Old Jan 22, 2011 | 09:34 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
So it took me something like 2 days to find out that taking the turbo off alone is a bad idea and the manifold is REALLY easy to take off, It took me less than an hour to remove as 5-8 of the bolts were lose...
The gaskets on the manifold are i think fucked as two are spilt into two bits now.
I have broke 3 spanners and smashed some glass bent a ratchet (so it broke the glass)
How it looks now
The red is the one that i just could not get to as every spanner is to big.
The blue one would have made like easy but the bolt is now round... so a spanner wont work
Thanks for all your help guys
Old Jan 23, 2011 | 04:53 PM
v man's Avatar
v man
get your self a 2wd manifold for when you refit as they flow better than 4wd and will make life easy if you need to take it off again
Old Jan 23, 2011 | 05:05 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Ill look out for one cheers. Would i need 2wd hoses for the turbo then?
cossie330
Oct 7, 2015 08:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
Fudgey
Sep 17, 2015 01:06 PM
hopper350
Sep 4, 2015 12:53 AM
