FAO Tiff - The Passion Ford Plumer
Sorry to bother ya Tiff
Do you know what this part is called,
Its from my Central Heating/Hot Water system at home,
It started to drip water a while ago
and now its getting worse
its an electro mechanical ball valve !!
can be controlled to open/close water flow - ............ wait for it ........................ electrically
but i aint no plumber rob - sorry
Rob
It is a Zone Valve
What it does is this.
Lets say it is on your Central Heating System. It is linked to the time clock and Boiler. When the time clock is set to turn the heating on, this valve will open and allow the radiators to get warm
Pop into your local plumbing merchants and ask for a Zone valve
It is a Zone Valve
Originally Posted by Rob@SCC Performance
Cheers Tiff.....
Any ideas on cost ? Not really....
Will i need to drain the water from the system ?? Dunno tbh...
any tips ?? Don't eat yellow snow.....
I'll get my coat....
I think they are around Ł40
This will be the easyest way to do it Rob
Turn the main water supply into tthe house off.
Drain the water out of the heating system by putting a hose on a drain plug that will be on thedownstairs Radiator valve or a Brass valve on the downstairs heating pipes.
Once the water is running out the hose, undo the vent plugs at the top of the radiators upstairs, this will get rid of the water in the heating system.
Once the water has stopped running out the hose it is empty and you can remove the Zone Valve, BUT keep a towel and bucket close by as there may be a little water still left in it.
Once all the new valve is fitted, turn the vent plugs on the radiators off, do the drain plug up and refill the heating by turning the water back on
Good luck and God Bless
Let me know how you get on Rob
Originally Posted by Steve@SCC
I can't hear any swearing yet...... so i'm guessing it might be getting done tomorrow
You will hear a bit more swearing in about 3 days when my Bill drops on the floor
Originally Posted by 4x4pete
Dont forget to tell him it might have a -> on it to show the flow
Rob
There will be an Aroow on the body of the valve showing you which way the flow of water is, make sure the new one is fitted the same
Just had a quick look on the plumb centre website and there is a few different ones....
will it come with the electrical bit ontop too ????
oh and the drain valve is that lump of white sticking out from the pipe that has been painted 4-5 times .. that you can now not recognise let alone get a screwdriver on to so you can actually open it
Job Done
Thanks for the instructions Tiff
You Really are a TOP Bloke
Now thats what being in a forum community is all about
none of that back stabbing and bickering bollox !!!!!
You Really are a TOP BlokeNow thats what being in a forum community is all about
borboyous
Aug 22, 2015 11:17 AM
Tell your a plumber Tiff, im sure we sell em for half that!!
