Cossie Fan Switch Plug
Old Dec 29, 2010 | 03:09 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Cossie Fan Switch Plug
I need a new Plug for the Fan Switch, does anybody know where i can get one.
Thanks
Steve
Old Dec 29, 2010 | 05:57 PM
opposite lock's Avatar
opposite lock
i could do with knowing this too
Old Dec 29, 2010 | 06:05 PM
Turbosimpsons's Avatar
Turbosimpsons
isn't there some on flea bay.
Old Dec 29, 2010 | 07:04 PM
janvanv's Avatar
janvanv
www.rallyanarchy.com
Aside from the Ford unique plastic shroud on the connector the switch itself is same as any 2 prong VW or Opel or Saab switch. Nice thing about those ordinary Bosch ones is the on/off temps are stamped in one of the flats of the hex and there is a huge--maybe 10-13 ---choice of on/off temps...
Old Dec 29, 2010 | 07:09 PM
martysmartie's Avatar
martysmartie
Try www.vehiclewiringproducts.co.uk they do most connectors, Iv'e just had a quick scout and they don't seem to do one.
Martin
Old Dec 29, 2010 | 07:12 PM
charlie luciano's Avatar
charlie luciano
Can get from ford but they are expensive, there was a thread about it recently actual price was on the thread
Luciano
Old Dec 29, 2010 | 07:45 PM
charlie luciano
Found the thread copied and pasted below
'6168566 and its £29.40 plus vat so about £34!!'
Luciano
Old Dec 29, 2010 | 08:00 PM
jamie's's Avatar
jamie's
they're the same as a lot of old escorts. fiestas sierras etc,
could cut 1 off at breakers and solder it in if your stuck
Old Dec 29, 2010 | 08:04 PM
janvanv's Avatar
janvanv
Luciano
Holy shit!
That's reason enough to look at the VW ones and chop off the Ford plug and crimp on 2 flat spade terminals!
VW ones here are maybe $10.
Old Dec 29, 2010 | 08:21 PM
charlie luciano
Originally Posted by janvanv
Holy shit!
You see how we get robbed of our hard earned cash in England
Luciano
Old Dec 29, 2010 | 08:42 PM
Look on auto marine for them, sure they do them, there are two sorts as they are handed off sets to the left or the right.
Old Feb 9, 2011 | 12:07 PM
coswurv's Avatar
coswurv
Anyone found anywhere that sells these plugs other than ford ?
Old Feb 9, 2011 | 05:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I found a plug on a old loom and used that
Steve
Old Feb 10, 2011 | 09:40 AM
coswurv's Avatar
coswurv
Surely someone who uses this site must know where to buy after market plugs, you see people using them on new looms for sale on ebay etc, cant understand why its such a big secret with things like this.
Old Feb 10, 2011 | 10:34 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Try Polevault, i think thats what its called
Steve
Old Feb 10, 2011 | 10:38 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
your best bet is cut a good one off at a scrappy, use a terminal tool to split it down then size up the terminals and order new ones from polevault/VWP etc then build it up with new terminals so it actually lasts a while. You dont really want to be bodging your exposed to the elements fan loom to more soldering and joints than necessary as its just more places for water to work in and the loom to corrode and fail.
or you could just bodge it for now and be forced to buy a new ryan fan loom or similar in a few years
Old Feb 10, 2011 | 10:41 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Have priced up all new parts for a loom and it comes in at under £150
Steve
Old Feb 10, 2011 | 12:42 PM
coswurv's Avatar
coswurv
Steve
Christ steve, what list did u make ?
Old Feb 10, 2011 | 01:02 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Engine wiring loom with all plugs wire etc lol, not a fan loom.
Steve
Old Feb 10, 2011 | 02:23 PM
Psycho Warren
Carbon Crazy
lol i was going to say, gold plated contacts on a fan loom might be overkill!!
steve is that with using standard thin wall cable or aviation/mil spec 55 wire??
also what protective wire sheild you using?
I priced mine up but i want to use kevlar wire braid to protect it but the amounts i need add about £70 to the cost compared to normal high temp braids.
Old Feb 10, 2011 | 03:33 PM
jon@work's Avatar
jon@work
Neither polevolt nor VWP do those terminals. I haven't found anywhere that does them.
Have you tried this place for Megamide - they sell by the metre :
http://www.printasleeve.co.uk/braided_sleeving.asp
Old Feb 10, 2011 | 03:45 PM
The Youth.'s Avatar
The Youth.
anyone know what other cars this fan plug is on as I need one!!
steve
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
simonmcf
Sep 22, 2015 08:40 AM
xrmalin
Sep 13, 2015 06:52 PM
