Subaru people-Help needed
Decided to get my car mot'd today as it's been sitting for 8 months now & this is perfect weather for it!
It's a 93 wrx import, got a full de-cat, apexi ecu, front mount cooler, td06 turbo (I think can't remember) otherwise pretty much standard.
Problem is when it comes on
boost around 3k it backs off
Like it's over boosting or lacking fuel?
I'll be honest I don't know nothing about these so I won't pretend to, I bought it on a whim last year as it was a nice car for money but need to sell it now. It passed it's Mot today no problems, so just that to sort on it now?
Thanks
Thanks
More likely its got a TD05 fitted mate... likely to be a 16g standard unit, still good for c350bhp though.
What happens when it 'backs off' mate?? Who mapped the car and what boost has it been mapped to?? Do you have the Apexi Power FC hand held commander unit??
Cheers,
Grant
Cheers,
Grant
My mate had a simular problem with his, the boost pipe under the intercooler had cracked, quite a common problem with the early ones. Might be worth pulling it off and checking the pipe and gasket, its a plastic Y peice iirc
Not sure who mapped it but it's got a monitor on the dash that I've never touched & I know you can adjust the boost etc but it was fine before I parked it up, always does it around 3k in any gear
mine are non road legal and aint the best when cold if im honest BUT DO NOT EVER FADE !!!,,,,, need to upgrade the rears though as the ABS gets confused easy
think they are called D2 compound, they are part of them racing pad range,,,,,, oh and they eat brake discs,,,,,,,, and i mean EAT them
You still after a box? DCCD any good?
Think he want 500 for it
Its from a type r my mate is breaking.
For that thou, it includes the lot! rear diff,DCCD ecu, dash, box the lot
Might get it myself but not sure on it fitting my 96WRX
The first thing to do is check the fault codes. The early Impreza's did not give as much problems with the MAF as the 98 to 00 models. There are 2 black and 2 green connectors near the steering column under the dash. Connect these together and put the ignition on. Count the flash codes, long flash 10's, short flash 1's. Let me know what the numbers are, and I will tell you what to do next.
John
John
John
John
Cheers,
Grant
Faulty MAF on a 93 will show up fault code 23 and it's done as described as above.
http://www.scoobypedia.co.uk/index.p...eadingECUCodes
John
John
John
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
