rad water frozen burning smell?
Went out to start the focus, i think the garage has just filled the rad back up with water without any antifreeze. I started the car to warm it up and could smell a burning coming from the bay area.
So knocked it off and opened the bonnet, seems the water in the pipes from the expansion tank and the rad has frozen.. Anybody got any ideas how i can get it going or will the heat from the engine just melt this OR should i not drive it while its like that?
cheers.
cheers.
if its just come from the garage after having hoses replaced and the coolant is frozen then they have not done they're job properly.
get onto the phone and tell them to recover the car and sort it out as it their fault and any damaged caused buy it they will have to pay for!!!
worst case cenario with coolant freezing is a cracked block.
if your lucky it'll just need a water pump and belts but could also pop core plugs, burst hose connections and also burst rad and heater matrix.
if im lucky it wnt need anything and it will have just been the belt slipping around the water pump pulley, the car wasnt turned on long enough to cause any kind of lasting engine damage i hope.
As said almost defo belt burning on the water pump pulley with it being stuck solid, do you have a fan heater that you can leave in the garage overnight, if you do try getting it pointing at the rad any heat will naturally circulate, the rad would likely be the first thing to get damaged, due to it being much weaker construction.
Next find a different garage or diy, invest in a haynes manual, focus is a really easy car to maintain.
I had the same problem with an omega v6 this time last year. The burning smell/smoke was the aux belt burning out. Once it snapped i turned off the engine and went for a beer! Once it had thawed out i filled it with water and it pissed out of every place it could. what was bought as a cheap car to sell on had too be sold as a non runner for a loss, as the engine needed a full strip down.
As said above, the garage has fooked up big time, and should recover your car and repair it, no question.
2 seconds is more then anuff if the water is frozen in the block, hope it as not fucked the water pump. Had to de-ice a pug 307 on monday every pipe had frozen, and it put a hole in the rad, had to take every pipe off run lots of warn water over n though the block n turn it over by hand
yeah i love all the positivity lmao, everybody just brings horror stories up of friends of brothers or friends cars etc etc.
ok heres a little possitivity for you mate. i've not heard of a cracked block on a focus.
hows that for you mate?
mind you, i've not heard of many focus's freezing up
think possitive mate, the worst case cenario is the rarer case so let it thaw out and i'm sure there will be little damage..........grasping huge logs now
Infact, thinking about it my first car, a mk2 cav sri froze up on new years day 1997, and the car run for about a minute squealing its knackers off until the cambelt snapped! me and vauxhalls in freezing conditions have never really got on. Never had a problem with the 25+ sierras i've owned.
if the pump didnt give way and stayed locked solid and just the aux belt slipped on it that will be what caused the burning smell and may need replacing.
fingers crossed nothing is fucked.
If this is a garage then clearly it's a very ameturish setup, even an idiot knows to fill with anti freeze remember it's not just there for to prevent freezing it also has a anti corrosion inhibitor. If it was me personally I would wrap the engine with a blanket etc and let it thaw naturally as one extreme of temperature to another is never a good thing, I certainly would not start or drive.
The pump runs off the aux belt the same as it does on most cars not the timing belt.
Martin
Martin
Martin
Martin
i would have thought if the belt was gonna slip it would slip in the first few seconds and kill the engine and if the engine had any other damage it would prob show up in 60 secs of running...depending on where the damage is.
i think your ok tbh from what you've said.
i personally would take the aux belt of and start the engine, leave it to get warm and once you are able to move the water pump by hand re fit the aux belt and run again till fully defrosted, switch off allow to cool then dump the water and replace with antifreeze.
focus will bleed itself if you hold revs at 1500ish with rad cap off a knackered w/pump will show up by either noise or cold spots on certain pipes/parts of the rad/ parts of the engine if not pumping
Is the garage closed till monday or closed fullstop?! If anything is fucked but u have messed around with it you could leave urself open to them turning around and saying you fucked it...............
Personally would be best to leave it and kick off with them monday and let them try and check it all so its down on them
*UPDATE*
The cars fine, had a full check over everything it was all defrosted etc and turned it by hand before starting it, started it let it tick over for 20 minutes and everythings normal
PANIC OVER! haha
PANIC OVER! haha
I've serviced a ford escort 2 years in a row, reported to the customer that it has no anti freeze, she doesn't seem to give a shit, really hope it freezes this year
Its prob had none inn since she had the waterpump done as cheap as possible at another garage, sure she thinks anti freeze is a mythical need
I hope you have added some antifreeze to the water lol
Steve
Another factor that people seem to ignor or not understand is that its ability to not freeze at sub zero temperatures is only one of its purposes, the second is that it is a rust inhibitor, water+cast iron block=rust, the most venerable parts are around the mating faces of the block which can lead to faliure. I forget how many times i have seen corroded blocks at the head gasket interface that are as good as scrap due to this
Mark RS
Oct 12, 2015 06:01 AM
