Back brake calliper stuck 02 mondeo
Old Nov 28, 2010 | 09:47 PM
actionfighter's Avatar
actionfighter
Default Back brake calliper stuck 02 mondeo
New Problem! My back brake calliper has stuck on my 2002 mondeo,just happened all of a sudden when i drop it down there seems to be a lot of slack on the handbrake lever,and when i drove it up the road a bit the break disc reddened,I just bought the car a few weeks ago and its been fine,but its freezing hard out tonight could that be the reason its stuck?
Any ideas???
Old Nov 28, 2010 | 09:58 PM
DS81's Avatar
DS81
Fresh onion..
They are common for handbrake cables and calipers seizing up, I fitted lots of them when I used to work at ford. Disconnected the cable down at the caliper to check whether its the cable or caliper.
Old Nov 28, 2010 | 10:21 PM
actionfighter
Would this be an easy fix if it is the calliper? and do you think the cold weather would cause it?
Old Nov 28, 2010 | 10:56 PM
Grantcos's Avatar
Grantcos
If you need a caliper, I broke a mondeo for spares, Ł10 + p+p ( Ł7 or something)
Old Nov 28, 2010 | 11:04 PM
botters's Avatar
botters
competant bodger
i have also had this be the flexi hose collapsing inside holding the brake on and eventually knackering the caliper ive had it more than once on mondeos
JoeyBoyden
Jan 4, 2024 02:36 PM
s1cab
Jul 26, 2018 06:11 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
